Hey guys
I've got an R34 GTR VSpec II and am about to do some mods to her.
R34 N1's
700cc Injectors
Walbro Pump
Apexi PFC
HKS Intake
Exhaust w/ High Flow cat
I have Z32 AFM's also which im trying to decide whether to fit or to sell, for the power those mods will produce (Hoping like 350 - 400rwhp) will i need Z32's? If not what kind of power will i need to be making to justify them?
Also, as far as the mods go, is there anything i have overlooked that will add easy power to the car that i should be considering? (Been told not to look at Cams or anything as the R34 GTR's don't really need them for that power, but i don't know how true this is)
Thanks guys!
Do the R34 GTR's come with N1's as standard?
Thinking about buys a 34 GTR ;)
No. Normal R34GTR turbos are ball bearing with ceramic tubines. The N1's have ball bearings and steel turbines, look very much like GT2530's and are capable of around the same power.
Cheers
Gary
I would stick with what you have at the moment and see what afm voltages you get...if they are not close to going full scale I would leave them.
The reason for this is if you went for z32s and they were only measuring upto say 30-40% of full measurement scale or voltage, you are not using the full input resolution of the ECU and technically you are losing precision in your tune..The ECU uses an A-D converter to convert voltage into a digital number. Not analogue. So voltages are either rounded up or down to the nearest value. If the ECU has an input range of 0-5v and you are only using 2v of that range then between each corresponding digital value would be higher and the resulting error would be higher..
An analogy to this,
If wanted to measure the length of something that was 87mm in length and you had either:
1. A 1 metre ruler with 1cm divisions
or
2. A shorter ruler say 300mm long divided into 1mm increments
The best option would be option 2 for measuring the 87mm. The 1m ruler would see it as (9cm) 90mm and not 87mm
Hope this makes sense..
Oooops, sorry, mis-read it... HP..! i got 303.1Kw at wheels similar plus internals and flowed head, flashy filters etc, plus FPR plus good boost controller plus more too.
N1's are superb Road 'bines tho, stick with them. there are a few variants as well i am told too!!, but i unclear what the variants are.
Good luck, enjoy the results, its a good start u got going there.
My orig's maxed out at just short of 300RWKW. btw.
R34's have smaller turbo potential than orig GTR ones too. Get some Orig GTR32's, more power from them, but still ceramic exh impeller am afraid , but better turbos than R34's
Edited by Richieb
An analogy to this,
or
Thanks a lot mate that does make sense (as an engineering student your analogy was right on the money to what i've been taught lol)
Thanks everyone else for your input also, ill leave the stockers and see how they fare and swap them out if necessary! Thanks!
sorry to hijac but...
Is this correct? Thought the standard 34 gtr turbos would flow more than the stocka 32's?
mike
mike
No standard 34 turbos are slightlty bigger than 32+33 and better because they are ball bearing but still have ceramic turbine wheels .
R32 - 0.42a/r compressor
R33 - 0.42a/r compressor
R34 - 0.53a/r compressor
http://homepage.ntlworld.com/tbroom/Turbos.htm
very useful for comparing stock turbochargers, lists all specs, wheels, trims, housing etc
Got that one paul, but the opinion here is stiil the best ones are the R32's.
R34 spool up quicker, but run out of steam. The Compressor wheel is smaller.
Edited by Richieb
An analogy to this,
or
+1 :spank:
What topic was being discussed?
OH..AFM's....... :laughing-smiley-014:
RB20 or RB25 just plug in ...that is what I have gone with.
But if you got $$$...Nismo all the way..at least you have bragging rights...... :banana:
ive still got my stock afms... made 287.8kw @ all 4's... that was on 15psi.. after that i ran tad over 17psi which is slightly over 300kw @ all 4's and afrs were still good...
they look like stock afms anyways.. as were injectors and fuel pump lol.. the stock GTR gear is pretty serious stuff really
hmm sell the z32 afm's. sell your standard ones. use extra money for a haltec or my personal favorite (short of 10g plus motec) the new wolf v500.
just buy something that uses a map sensor and be done with it
MAP sensor and multiple throttle bodies are not a good mix for a road car.
Cheers
Gaery
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
