Was driving to the panel beaters when I saw an R32 ploughed into a pole on Mcintyre Rd. The car was black/grey and had P plates. It was quite a serious accident. Came back from the panel shop to see police cars, ambulances, and fire brigades. Saw a stretcher setup, but wasn't sure if there was anyone on it. My mom said she drove past and saw the car seat from the car, about 10m away; not sure how that happened though.
Does anyone know if the occupants of the car made it out alive?
**EDITED POST DUE TO HEARSAY**
Edited by mikymouse
black box recording of todays events.......
"hey mayte watch dis!!!!!"
zuuuuu zuuu zuu tu tu tu screeeeeeeeechhhh CRASH!!!!
that is all
maybe they were driving safely, until some kent with an emo white r32 4 door came dosing out of nowhere on 2 wheels and pushed them into the pole...... :P
but in all seriousness - there are always more idiots on the roads when its wet - just yesterday some kent did a u-turn in front of me, and decided to slip the rear out across all 3 lanes on ferntree gully rd.......rain and bad weather brings out the dickheads
end of the day, most of us do it, and we all no wat can happen if we dont no our limits in our cars...
just be carefull guys cause that extra slide could mean ur life an worse a mates life in the passenger..
first of all before we go futher , the car was a R 32 , gtst , its dark blue, it hit a pole due to some one in front of him deciced to slam the brakes on and gave the driver of the blue skyline no option to move futher left , one problem there was a car slower than him already there , givin that the driver was going a little faster than all other poeple in front of him no choise than move again left resulting in striking the pole in the worst possible part of the car , hitting the drivers side wheel and the wheel went back right in the drivers foot area , trapping the driver for 2-3 hours untill cut out by fire mans , the car was totalled in this crash , the driver was taken to hospital with serious injiures, the driver could of slammed in the back of the car in front possible pussing them in front of a big truck comming the other way , i know this guy avoided massive crash with collideding with other cars and took full forse in the pole of his own car , i know this , i was right there 20 ft away , and i praise the driver for his actions for more injuires to others drivers , this guy is known to most of us , and i hope he has a speedy recovery in hospital , by the way the seat was still in the car , the fireman cut the drivers door off and placed in in front of the crash scene ,
enough jokes about this crash the guy is in SERIOUS condition in hosipital , in respect for family and freinds close to the driver !
He must have been doing a fair speed to cause so much damage, did his brakes fail???
why wasnt he travelling at the same speed as the traffic infront of him.??? Probably would have meant he could stop in plenty of time..I hope the guys alright.. but maybe it'll teach him some common sense travelling too close or travelling at a speed which will not enable you to stop in time to avoid an accident is your fault and not matter how he drove to avoid traffic its his fault.. still i hope he is alright.. but it might all remind us not to be in such a hurry all the time..
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
