:rofl: Hey guys i am just importing my first jap car and i was wondering what everyoe thinks. Also i would like a big brake upgrade if anyone knows where to get one cheaply.
hope you like the car
NISMO FULL BODY KIT
N1 HEADLIGHTS
TRUST 2.7 LITER
TRUST HIGH CAM SHAFT
HIGH CAMSHAFT INTAKE 272
HIGH EXHAUST CAMSHAFT 280
TRUST RACING VALVE KIT
TRUST ADJUSTABLE SLIDE CAM PULLY
CYLINDER HEAD TUNNING WITH BIG VALVE
TRUST 1.6MM METAL HEAD GASGET
TRUST 87mm FORGED PISTON KIT
TRUST FORGED CONROD
TRSUT FORGED FULL COUNTER CRANK SHAFT
HKS GT 3037 S TWIN TURBO WITH SPECIAL MANIFOLD KIT
SPECIAL RACING TWIN WASTE GATE
TOMEI FUEL DELIVERY SYSTEM
SARD 1000CC INJECTORS X 6
NISMO FUEL REGULATOR
NISMO TWIN FUEL PUMPS
HKS F-CON PRO COMPUTER
HKS EVC
TRUST 3 WAY BIG INTERCOOLER
TRUST 3 WAY ALLOY RADIATOR WITH ELECTRIC FAN
HKS OIL COOLER
HKS TWIN POWER FLOW
SPECIAL ALLOY SUCTION PIPE
OS CROSS GEAR CLOSE RATIO TRANSMISSION
OS TRIPLE PLATE CLUTCH
NISMO LSD
HKS HYPER MAX DRAG ADJUSTABLE SUSPENSION
DRAG TYRES FITTED NOW
APEXI REV/SPEED METER
ALLOY OIL CATCH TANK
GREEDY WATER TEMP METER
GREEDY OIL PRESSURE METER
GREEDY TEMP METER
GREEDY BOOST METER :blink:
https://www.sau.com.au/forums/topic/213841-what-you-think-of-my-r32-gtr/
Yeah talked to Danny its going to cost a little to get it complied. Thats no dramas, the car doesn't get here until the 27th of april, i can't wait. i have already bought a set 18X10 weds to go on it. i want to get a set bride stradia sports seats and bigger brakes. Im thinking grex. Any other ideas on brakes would be good. Also what is a good club in perth to join for track days etc?? :rofl:
Ouch thats a one huge powered car there. You will find it does well at the drags more so than the track. If it's setup right thats a a 9 second car. You need to budget for a motor strip down / basic rebuild if you intend to give it a go at the drags. That sort of power mandates more frequent rebuilds if it's used.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
