The ticking sound can usually be rectified with a higher viscosity (thicker) oil. Many cars of all makes with higher kms usually make a ticking sound. Subaru's are especially renowned for this. How many kms on the car and did the ticking occur once you changed the oil?
I doubt it would be your belts as the sound wouldn't go away once the engine is warmed up.
https://www.sau.com.au/forums/topic/213844-tick-tick-tick/#findComment-3776819
Ah i see, i brought the car at 102,000k and now its done 106,000k. The oil that i used was motul turbo light, is there a way to reduce the noise? I like it when the motor is quiet.. An also i did not hear the tick once the oil was change it was not until weeks after
Edited by gazal
https://www.sau.com.au/forums/topic/213844-tick-tick-tick/#findComment-3777003
Reduce the noise by changing the oil to what it was before basically. Also now that we are approaching winter your car will get even noisier on start up. This is normal. You learn to live with it, but you can reduce the noise with the right oil imo.
Don't get 0W-xx viscosity. You don't need it. Good for revving out easy but too thin and by rule of thumb will be the noisiest. If you go by the Nissan handbook, they recommend their patented 7.5W (for everything!), but that oil breaks down easy (semi synthetic). I found Motul 4100 degraded quickly too (also semi synthetic). Motul Chrono 300V was much nicer to the ears and engine. Expensive stuff though. It is a case of sticky lifters/tappets and some cars are more prone than others. In my experience it has been an oil thing and has a direct correlation with the outside temperature as you will notice.
This is just from my experience and of various mechanics recommendation.
Edited by HotPlates
https://www.sau.com.au/forums/topic/213844-tick-tick-tick/#findComment-3777100
Cool, thanks for the feedback guys.. So what is it? the oil or the gasket? i dont know much about cars and if there's something wrong i'll take it to a workshop. I rather find out what could be wrong with it so that if i do take it to a workshop i don't come out with a new car..haha
https://www.sau.com.au/forums/topic/213844-tick-tick-tick/#findComment-3777432
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
