  • Replies 65
Posted Images
Rays 57's $1800 with rubber (meaty tread) no gutter marks - 1 scratch on inside of locknut hole due to a shop using wrong tool , its not that noticeable
all parts NEG on prices
buy multiple items and ill give cheaper price on total cost
come on people need to buy a trailer.......
Standard cat - free to good home
Dude.. WHy u givin ur cat for free? Metal recylers give good cash for it.
I sold 5 cats for $60 each to this shop in melb...
Rays $1500
Boost Ctrl $400
GTR Grill $100
Strut brace $100
Afew intake pipes (custom) was for my topmount t04 - Throw offer
Intercooler engine crossover pipe $200
Custom dump + front pipe $380
camera is not working
want to see? we can meet half way or we can work something out
need to get rid of these items
