i find that removing stickers was really simple on a hot day, the heat made the sticker easy to peel off. no gluey residue nothing. a hair dryer may also work, but i dunno whether thats good for the paint, altho technically should be okay? coz its just simulating sunlight anywayz.
Hey Jet
I had to remove some of the stickers of my car and this is what I did. Used a hair dryer to make the peeling a bit easier. With the left over glue I used a Grease/Wax remover spray and let it soak for a while than just wipe it off. Some time it takes a few spray to get everything off. Than clean the car, wax and polish.
The paint was alright afterward and no damage done.
