a bottle of Meguires clear plastic polish (little blue bottle bought mine in K-Mart) Polish the outside with that ..... if still murky look at getting it done proffessionally ..... unfortunately while this stuff brings it up clears as ..... it quickly becomes murky again within 1-2 weeks..... but its something that only takes a minute to do so i polish my headlights every second weekend.
https://www.sau.com.au/forums/topic/21431-murky-headlamps/#findComment-453262
i had some plastic polish a while ago some jap stuff, worked great, went missing somewhere so if anyone wants to use it, just post up and i am sure it will turn up. and then juss pass it around from there,
now where was this $40 in the inside clean etc, cos my prob appears to be on the inside dont know how or why, but yeah how do i contact the $40 hero
https://www.sau.com.au/forums/topic/21431-murky-headlamps/#findComment-456309
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
