Hello to all that read this,
Im just wondering what are the differences between the RB25DE and the RB25DET,
And dont say one has a turbo or puts out more power,
I want to know the nitty gritty, cams, pistons, crank, rods, head etc
I know compression ratio is high in the NA, but how is this achieved?
https://www.sau.com.au/forums/topic/214425-rb25de-vs-rb25det-r34-neos/
turbo is 9:1 CR, N/A is ~ 10.2:1 CR, achieved by different pistons.
Cams are the same, i think just on the turbo the exhaust cam gear is shifted a couple degree's.
Thats the internal difference, external theres the Injectors (370cc vs 270cc), ECU (to power injectors + different map & limiter), obviously different exhaust manifold, intake piping, things like clutch is different, different gbox.... thats about it...
The springs on the NA's are softer than the turbo ones.
And one has a turbo and puts out more power :rofl:
Remebering that 34's have a different head than the 33's and 2's because of the VVL
i know the r33 rb25de have softer springs than the det, but i've heard the neo engines are the same for both turbo and na
also if the pistons are the only thing different internally, i wonder if the na shares the same gtr rods as the neo det?
anyone pulled a na neo apart yet?
Edited by R34GTFOUR
  • 7 months later...
All R34 GT4s do not have the tiptronic functionality. From memory the gearboxes are still physically the same (RWD and AWD), just no tiptronic for the GT4 and RB20DE NEO. Tiptronic is only for the RB25DE and RB25DET
GT-V (which is N/A) has same suspension as GT-T, otherwise standard GT has the softer suspension (and also smaller rims, and probably other differences).
i was talking about valve springs, not suspension coil springs :)
Hi all,
I would like to confirm the different on the R34 GTT and R34 N/A i've check out my mate's car which is a TT on the dash it have HICAS, Slip, TCS display, when on my N/A 34 it dosen't do that mean i dont have these feature?
If anyone have the spec fact sheet for both these cars?
Cheers
:P
How can i get a LSD installed.
Ive seen a nismo one on NENGUN for 1.8k .. how would i install it.
MRXTCZ
You gotta drop it out of the car.
To do that you need drop drift shaft, prop shaft.
Open up the housing.
And change the gears.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
