Doh!!!! That is so terrible for a 34 to be in that condition.:laugh::D
It makes me real mad to see people trash other peoples things, if that is what happened????
Sounds a bit funny with all the damage that the lights were still ok and not damaged
On another note
Would be good for some spare parts now. It could only live on if someone was real keen.
Anyone know where it is now????:P
Its a 34 thats for sure
but the photos seem very fishy...
notice the leaves and shit pushed into the gap between the front guard and the pasangers door...
might have been on its side by the looks of things, and what caused the bonnet to be like that and yet the front bar is still pretty good...
looks like a semi strip before crash if you ask me...
my semi conclusionits a stolen car thats been dumped
surly someone know something.... looks to me its been rolled on its lid down a steep bank and all the force has ended up on the bonnet coasing it to be how it is. but yes someone knows something. it has to be someones loveable car
Damn! it would have to roll and slide down something bonnet first to be consistant with that damage
could it have run up the back of truck trailer, so the bonnet gets peeled while the rest just runs under?
I saw a 300zx drive striaght into a barrier on mt NEbo causing almost identical damage to its bonnet, as the car went sorta under the guard rail it just peeled back the bonnet. looks similar.
still no one owned up to this
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
