Be involved in a real race team! Pit crew volunteers needed!
On the topic of this, i thought this would be appropriate.......very funny stuff ........no one here is a Maori??? lol
Modena, Italy.
> >The Ferrari Formula 1 Team fired their entire pit crew yesterday. The
> >announcement followed Ferrari's decision to take advantage of the New
> >Zealand Government's "Work for the Dole" scheme - and to hire unemployed
> >Maori youths.
> >The decision to hire them was brought on by a recent television
documentary
> >on how Maori youths were able to remove a set of car wheels in less than
> >six seconds without proper equipment, whereas Ferrari's existing crew
can
> >only do it in eight seconds with the aid of millions of dollars worth of
> >high-tech gear.
> >This was thought to be an excellent yet bold move by Ferrari management.
> >As most races are won and lost in the pits, Ferrari would have an
advantage
> >over every other F1 team.
> >However, Ferrari got more than they bargained for, as during the Maori
pit
> >crew's first practice session, not only were they able to change all
four
> >wheels and tyres in under 6 seconds, but within 12 seconds they had
> >re-sprayed, re-badged, and sold the vehicle over to the McLaren Team for
> >four cases of Crown Lager, a gram of smack and a quick glimpse of David
> >Coulthard's bird in the shower
Ando
  • Replies 45
PranK,
Good luck dude I hope you find something soon. Being unemployed for 3 months myself, I know it's pretty tough out there in IT ATM.
What do you want to do for a job when you are ready to start again ?
Cheers,
Hi All,
Firstly, thanks to all that volunteered to help out with this. The promotors have, however, clarified what the "pit stops" will be....we just have to pit, remove a velro sash from the car, get back in and head off! So, no need to get a crew together to change the tyre, only cheering is required.
Everyone is still welcome to come along on the day, as well as the mighty daewoo 1 hour race, all the regular categories will be running as well.
And PranK, does this mean we can cruise before midnight now :O
Well, sash removing cheer squad, I havent got confirmation of the programme for the weekend yet (as usual), but we will be out there. There will be races on from 9am-5pm, we'll prolly be there a bit earlier for scruitineering.
We should have one of the corporate boxes (usually the end one), so I'll see you guys there.
BTW, for anyone who would like to get into racing, the organisers of the daewoo series are running this contest for a free season, its being run in 2 weeks:
http://www.skylinesaustralia.com/forums/sh...&threadid=22864
Well, we've got the times for the combined touring / daewoo races:
Sat: Qualifying: 10am, Race 1: 12.00
Sun: warm up: 8.30, Race 2 (1hr): 1pm
See y'all there :)
Well its was a good day out (apart from the small issue of remodelling the right front of the car :P
I'll be starting from 4th tomorrow, which has me in with a good chance.
I do actually still need another volunteer to help out tomorrow, we need someone to act as car controller when the jump out/jump in happens :P.
Whoever wants the job, I'll need you out there at 8am tomorrow so we can practice the stops during the warm up.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
