  • Replies 108
Not my point dude lol Neither is the HKS supra running a 4.8ltr V8 TT... or the HKS 180sx running a RB26DET... they are built for speed... OBHAVE was built to be the fastest 'GTSt' which to me is a RB25DET powered skyline... i'm not saying your wrong but i am jus saying his is hte fastest street gtst with an RB25 in it.
I checked out a R33 Skyline with the trust td06-20g turbo on it, it had 550cc injec reprogrammed ecu, nismo fuel pump, external gate, trust manifold + cooler and apexi exhaust, was making under 240rwkw... my current car has a gt3540 and is making 300rwkw using a rb25... hopefully will get dyno'd soon and hoping to making around the 350rwkw mark maybe more. The trust turbo started spooling up at 3000rpm was on full boost by 4500 or just abit after. my current turbo spools up earlier and is way more responsive aswell. Instead of spending the money on a trust td06 id rather go for a garret turbo and save $$$. My cars on 1.2 bar the r33 with tdo6 was on 1.3 but running standard internals.
No offence, but you bought the Skyline you are driving around already with the Garrett turbo on it. You had no imput whatsoever into the design of the motor or turbo setup, nor did you have any financial or availability concerns determining what turbo the car was going to run.
There's more than just a flat out money decision when purchasing a turbo.
Edit: How can you compare a dyno'd car with an unproven value? You can't make a valid comparison on the vehicles power...
No offence taken buddy. The reason i bought a car with all the set up on it is because i couldnt afford to build a skyline to the specs my car is at now. Now the price between the car i bought and looked at was only 2k. Not only that the car i bought is in much better condition.
I understand what your saying here "You had no imput whatsoever into the design of the motor or turbo setup, nor did you have any financial or availability concerns determining what turbo the car was going to run" but i did have enough money to choose what car i was going to buy and what i was looking for. Both cars were dyno'd and had dyno sheets and spec sheets. Looking at both of them the car i bought was much better and worth its price then the skyline with the tdo6.
"There's more than just a flat out money decision when purchasing a turbo" thats right. It depends on many things.
But what i stated was my opinion and what i experienced. Im not critisizing the td06 turbo... its each to there own.
Originally posted by Roy
RNS11Z... can you tell me what exhaust housing the TD06-20g was running on that R33? An did i read right... about 230rwkws at 1.3bar
Im not too sure about that. Im not so cluey on turbo a/r sizes. All i know is that it was using the TD06-20G turbo.
And it was either making 224rwk or 234rwkw... Im definately sure it was not over 240rwkw with standard internals and re-programmed ecu
True that, though how much is it for a Trust TD06-20g turbo?
/cough $3500!!!
Ok that was a shameless plug, but there is not much price difference between a brand new td06-20g kit and a T88 kit. Maybe you should be comparing your setup to a motor with a T88 and internals as well?
Edit - Like Leewah's? :D
YBSLO4
You are DEAD WRONG about the Wolf3D V4.##!
Hear are some facts on the new ECU:
-Fuel and Ignition maps are tunable every 125rpm and have 16 load bands.
-Fuel increments are 0.004mS
-Ignition increments are 0.035 Degrees
-Idle speed control-adj. every 2 degrees of engine temp.
-Boost control-adj. every 125rpm
Heaps more features are also included in the package. I would like to see the tunning features of the Power fc, just as a comparison.
I have had the WOLF in my car for about a year, and has been running sweet (once it was re-tunned properly).
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
