Plans have changed and motorvation has ceased. Selling as is. Needs prob a day of solid work to get running, engine anchillaries hooked back up. left 1/4 window to be installed and ignition re-fitted.
1984 DR30 sedan
Silver over black
114xxx km
Late model tail lights(left has some light cracks)
King springs and monroe shocks at each corner
2.5 inch exhaust
Bosch BOV
Other than that its bog stock. Long nose R200 clutch pack LSD standard. Body very straight. Top 1/2 of the paint is great. Bottom could do with a touch up.
Most would know the potential the FJ20 carries. 170rwkw achievable on 15psi through stock turbo. 300rwkw on stock bottom end!
Sunshine Coast
0415291321
$2800
No low ballers.
https://www.sau.com.au/forums/topic/215034-fs-dr30-sedan/
its a DR30 hugh, not a MR30
1800TI - 1.8 L Z18S SOHC I4, 105 hp (77 kW), later models 1.8 L CA18S SOHC I4, 105 hp (77 kW)
2000TI - 2.0 L Z20E SOHC I4
280D GT - 2.8 L LD28 SOHC I6 Diesel
2000GT and Passage - 2.0 L L20E SOHC I6
2000GT Turbo, Passage and Paul Newman Version - 2.0 L L20ET turbo I6, 140 hp (103 kW, 206 N m)
RS - 2.0 L FJ20E DOHC I4, 150 hp (112 kW, 181 N m)
RS-X and RS-X Turbo C - 2.0 L FJ20ET DOHC turbo I4, 190 to 205 hp (140 to 151 kW, 225 to 245 N m)
https://www.sau.com.au/forums/topic/215034-fs-dr30-sedan/#findComment-3798671
is this the DR30 that was on ebay around christmas time???
very good price, i mean half the work is done when you buy something like this....
an FJ20det alone is worth over $1500 these days....
good value.... VERY good buy to whoever is looking for a good project
https://www.sau.com.au/forums/topic/215034-fs-dr30-sedan/#findComment-3801394
Nah highly doubt it was on ebay.. Previous owner wasn't motivated in selling. I remember there was a coupe on ebay around that time though??
Its a relatively low km gearbox so the synchro's should still be sweet unlike so many other DR's. The smart thing would be to wreck it. The diff is worth $900. I just don't have the motivation. Plus I would rather someone resurrect it and look after it.
I presume its had a respray at some stage as there is only 1 20c size bubble of rust next to the rear 1/4 window.
https://www.sau.com.au/forums/topic/215034-fs-dr30-sedan/#findComment-3801678
What's it need for rego?
When was it imporetd? Is all the relevant paperwork with it? Has it evern been complied, or was it brought in as a 15 year old import?
I know someone looking for one of these. I'm seeing him tomorrow, and will pass it on. (He rebuilt one of the ex Gibson R30's a couple of years ago and is itching to get one of his own now)
https://www.sau.com.au/forums/topic/215034-fs-dr30-sedan/#findComment-3802339
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
