  • Replies 41
Nope.One is a 3040 the other a 3540
3040 is about a 600hp turbo
3540 up to about 750hp depending on housings.
Wouldnt go smaller than an .82 on a RB30
3040's come in 500, 550, 600 depending on the compressor wheel chosen (different part number) :)
I had a 600hp one, others i know have a 500hp one
I agree 150%, perfect turbo for the 25/30 still giving great response with good peak and a stonking midrange
yup im agreeded guys. thanks for every ones input. was of great help.
now its 2 grand investment time lol
I dont think you can go wrong with anything around the GT35 range (either a GT3540 or something slightly smaller, GT3240), they will easily give you the power you want (rated around 600-700HP) and beyond and being a 3L this gives you the displacement to spool it up quickly.
Quick edit: Just noticed you have 500cc injectors, are they actually 500cc or nismo 555cc injectors? Either way, if you want to go much over 300, say 330ish, id probably recommend 740cc injectors just so you arent running the 500cc on such a high duty cycle.
i'd have to agree on both, especialy running a 30 block
im running twin garretts 35/40 one hiflowed the other standard, and bosh 740cc injectors on a low impedance.
rb30/26dett head.
My 2 cets worth, GT35/40 heaps of them around as they are the ones on BA Falcons, proven to make obscene power. I was going to put on of these on my VLT, i think they rock just just my opinion tho
hmm then gt3540 is whats on Eastons r31 black pearl drift car... cause i know he is running an xr6 turbo...
i know that things goes hard too . it seems most ppl are recomending very similar turbo
yer i will be using bosch injectors as my bro ownes the dealer down here
ok im guessing these are essentially the same turbo with different exhaust housing sizes???
one is .82 and one is .61???
will the .82 mean more lag?????
hey mate, just to clarify for you the 3540 and 3582 are the same thing. Steer clear of the xr6 turbo, boost control is a nightmare with them i found
Edited by DCIEVE
Thanks DCIEVE
Yes i have worked out they are the same thing lol. too bad no one else could put it so simply lol.
Spoke to "un named" seller today and i can get trade price of $1600 for a new gt3540 with the .82 exhaust housing...
Hows this price???
need to get manifold too, he quoted 900 which is a bit excessive so ill keep looking.
peoples thoughts...???
are we talking internal gate or external?
i asume ext.
what brand was the manifold?
yes externally gated.
unsure on the mainfold brand!
having a look on ebay and stuff but looks like home made crap. ill find a decent one for a good price if i persist :wub:
HKS 3037 or TO4Z...
wtf?
how can u recommend a HKS GT3037 and then go and recommend a t04z
both turbos are no where near each other so how can u recommend one and then the other??
like if u said GT35R and t04z its abit more understandable
IMO
for a Rb30 / 25 setup and aiming for 300rwkw i would recommend the GT35 with .82 exhaust housing
this would be a very responsive setup
DO NOT go any smaller then a .82 exhaust housing on a 3L engine!
Edited by STR8E180
Well you wouldn't promote Garrett now would you?
Your aware of your warning, if your just here to plug your parts, ill send you on a holiday
LOL +1
Yup as i have heard also. This being due to internal gate i do believe?
Ive gone externally gated.
$1600 aint bad. I was looking at paying $2200 back a couple of years ago, that was for an internally gated one.
Yup $2200 is still about right for retail but i got a work account with the peeps im goin through :cheers:
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
    • Yep four point harness. Mounted to a bolted in brace running behind the seats. Dont use it for daily driving tbh but good to have for when its needed plus it looks cool.
    • I had to double check the thread title r34 gtt offset advice lol. Thought maybe i posted on the wrong thread. 😂
