hahaha, yeah i cant wait till the engine is done, money is the real issue though, its gonna cost me heaps, so its gonna be a slow project. but will be well worth it. Im aiming to have it done early next year.
  • Replies 71
yeah it does, ive got it flanged so i can put a replacement pipe in. That makes a real difference, once the car hits 3grand it just moves, with the cat on it kicks in from about 4500rpm, im gettin a custom track exhaust, from extractors will split in to 2 11/2 inch pipes and exit at the side :D will make a hell of a difference i reckon
yes an NA car does need a certain amount of backpressure but this is already happening through ur headers and the rest of the exaust system, gutting the cat deristricts the exaust a fair bit and is definately a noticable power increase, those extractors where 285 bucks plaus 150 for fitting, the most worth while mod i have done yet.
by keeping the exhaust at 2 1/2 it keeps the back pressure at a good level, gutting the cat is illegal of course and it does screw things up abit u have to gut it and put a stealth pipe in it, visible as a cat, but its a pipe inside a box. my old zorst was 2 1/2 all through
i've got an auto r33 - but its the 5 speed auto version with a really short 1st which helps acceleration - i get around 7.5-7.8s for 0-100 - i've god k&n pod filter with divider in the engine bay, that's it (running 98 RON petrol all the time and service every 5,000 with anti-friction oil - i reckon it helps!)
i beat a wrx with a bov one night - that was pretty funny i think the guy was a sh!t driver tho, and i can keep up with my mate's ca18 silvia (rebuilt and boosted to 12psi)
8.2 sec is a bit slo for a '33 - even an auto - do u torque brake?
i think its slow too!
i wana go against an r33 with the same mods or less and see how i go..
do i torque brake?
i duno wat that means
but if u mean start of with ure foot on ya damn brake and on the gas and take it of brake
then yea thats wat i did to get that time.
try doing a 0-100 with the stock wheels, since i put my 17's on it has lost a little accelaration (diameter is slightyly bigger) i got 225/50/r17 on mine, if urs are 45 or lower then it really shouldnt make a difference, but tyres and width can also make a difference. u lose out on speed but handling gains heaps:)
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
