Wanting to no what the difference between the r32 gtr and gtst fuel tanks as mine is in need of replacing real bad.
First Question is the gtr one plastic and if so how hard is to swap over?
Second question what other options do i have to replace the fuel tank with?
Cheers James
  • 1 year later...
I changed the fuel pump in a GTR last week and a GTS about month ago. The GTR pump sits in a cradle that is attached to the bottom of the tank. The GTS pump is attached to the sender and hangs from the top. You might be able to use the GTS sender and pump in the GTR tank if you take the cradle out.
  • 1 year later...
