Hi, I can't remember your nick, but you had a dark coloured R33 GTST with an Alpine TV and DVD player. My mate had the white Tommy Kaira R33, I was the one who closed your boot rather roughly. (sorry) Anyway you mentioned being able to get things cheaper off Yahoo Japan. He's interested in getting an Alpine TV like yours, (especially) an Apexi Power FC computer and possibly a FMIC. Is there a site that I could look at to get these items, or I think you said something about having a contact who could organise it? Thanks for your help.
https://www.sau.com.au/forums/topic/21547-r33-last-friday-at-bunnings/
  • Replies 53
yeah it's the bodykit that's different, Tommy Kiarara written everywhere inside.
This R32, was set on 16psi..but found out it was detinating, so have brought it back down to 14psi. Until it gets remapped. But yeah spins a bit for sure..
I better shut up about his car now, he'l tell me off for being a big mouth! ha.
The 33 Tommy Kaira Stang is talking about used to be owned by my b/f's brother who sold it to John a few months ago as he wanted to buy a house.
Tommy Kairas have the huge front and massive rear wing which Troy got rid of cos he said it resembled a shopping trolley. We both bought our cars from the same place in the same week! I wasn't sure on what to get as they had black and white 33 Tommys there at the time - but I settled for mine cos it had lower k's, was cleaner etc etc.
We reckon it definitely has a cam or hi flow or something cos it gets up and goes like no other 33 I've ever been in. Makes mine feel like a slug!!!
Iam the one with the R32 Tommy Kaira.It has a gtr gear box, vielside computer,full tommy bodykit including adjustable wing. Other things that have been added are tein adjustables,bigger turbo,aftermarket intercooler,electronic boost controll and the list goes on.I bought the car a few weeks ago and definetly have no regrets exept iam told that vielside computers cant be remapped
a while ago when i was skyline hunting, i saw what appeared to be a white r33 tommy kaira at redline motorsports - was asking something like
30k, but it wasnt my taste i.e bodykit. But if i had known its potential over gtst dammnn i would have bought it. btw it looked nice, Tommy kiara written all over it - interior and exterior, as someone mentioned.
Nozila - thats where it came from - he didn't pay anywhere near 30 for it though!
I considered buying it too but the kit wasn't exactly to my taste either...I opted for the boring M Spec instead. And the Tommy had heaps of stuff done to it when it came to Australia and I didn't particularly want a car that had been modded.
When it came here it had a huge FMIC and aftermarket computer, and all the goodies. They couldn't even get it to run on Aussie fuel so they had to remove the computer and they also removed the FMIC for some reason to try and get it to run.
Probably sold all of the gear from it to make a bit of extra cash!!
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
