Hey it would be great if i had lots of money to throw at my car but like i said i've only got $1000 to spend and i want some more performance...
Just so you know, all my s1 33 has done to it is...(try not to laugh)
r32 wastegate actuator,
r34 SMIC,
hi flow cat,
3in cat back
and earthed solenoid wire for constant high boost mode...
I know i'm not left with alot of options as $1000 won't go far but i want to make the most of what i have and try and spend my money on something that i will feel the power difference..
Can anyone recommend any options?
After this i'm not goin any further with the cars mods and i don't have any specific power goals i'm trying to achieve.
(I've had a lot of well meaning mates recommend stuff like upgrading injectors and fuel pump or to get a FMIC or get myself a dump pipe and other crap but i have little mechanical knowledge and i don't know whats really worth it, so hence me throwing this out to you guys.)
Any advice and personal experience would be awesome!!!
https://www.sau.com.au/forums/topic/215607-1000-to-spend/
  • Replies 76
Injectors you cant do because its a stock ECU and you dont need any bigger injectors because your stock ones arent maxed out. Fuel pump once again doesnt need to be done because its not maxing out. I reckon the best bang for buck that you can do is getting a split dump pipe, something like an x-force one. They are like $350 or something and you'll atleast feal the difference. Spend the remaining money on something else.
Theres not much you can realisticly do with a $1000 that is going to give you a decent "performance upgrade".
However if you want it to handle better, spend the remaining money on front and rear sway bars, which again for the money will be the best handling modification that you can do.
Edited by PM-R33
https://www.sau.com.au/forums/topic/215607-1000-to-spend/#findComment-3808979
Yeh i know its a bit of a drag only having such little money but i just got married and its all i really can allow so i'm tryin to make the most of it...
i probably should have been more specific but i just want more power as suspension has already been up graded to all nismo items(shocks, springs, struts ect) along with upgraded brake pads so handling and stopping is good, i don't want to go any further with that...
So a split dump pipe you think...
any thing else?
Thanks guys!!
https://www.sau.com.au/forums/topic/215607-1000-to-spend/#findComment-3809019
if you shop around you should be able to get a FMIC kit and front section of your exhaust for $1000...
You should be able to fit it all yourself, they are both easy to do if your not confident just take your time...
I think the best mods are the one's you d yourself a lot more rewarding.
https://www.sau.com.au/forums/topic/215607-1000-to-spend/#findComment-3809036
Apexi SAFC = Super Air Flow Computer/Controller/whatever. its a piggy back engine management device that plays with your ecu's airflow readings and uses that to tune the car. afaik, they dont make em anymore. there are a couple of good threads on here about them. do a search
https://www.sau.com.au/forums/topic/215607-1000-to-spend/#findComment-3809060
Took you guys long enough....yes...an safc or some sort of engine management is the FIRST thing i would do...
You mean on stock skyline the first thing you would do is a form of engine management :D
Then get and intercooler, full exhaust and more boost which then needs to be retuned again for the new modifications throwing off the original tune......IMO engine management should be done after basic mods so you only need to potentially tune it once if thats all your doing out of the stock turbo. I reckon so far he's doing the right thing.
https://www.sau.com.au/forums/topic/215607-1000-to-spend/#findComment-3809132
Lolz...let me rephrase...
In this case...it'd be the first thing i'd do...he already has an exhaust...and a 34smic...he also said he wanted to "feel" the difference...and if thats the case an safc or a better form of engine management would give the biggest gain in power and driveability...don't you think so?
https://www.sau.com.au/forums/topic/215607-1000-to-spend/#findComment-3809183
how bout gettn a FMIC and help that catback of yours breath a bit better with front/dump pipes.
50kw gain i rkn
wdh is a SAFC gonna do if his car cant even breath or cool itself.
up the boost to about 12psi with the FMIC and the better flowing exhaust.
should bit u around 180-200 if your lucki
Edited by R34NRG
https://www.sau.com.au/forums/topic/215607-1000-to-spend/#findComment-3809243
x2
https://www.sau.com.au/forums/topic/215607-1000-to-spend/#findComment-3809317
he has a SMIC (good for approx 200rwkw). FMIC is unnecessary at this stage. front pipe has already been said. SAFC is a tuning tool. he asked for bang for buck. doesnt mean reliability is thrown out the window.
a car is going to run better with a tune and front pipe than it is with a FMIC and more boost thrown at it and no tune
https://www.sau.com.au/forums/topic/215607-1000-to-spend/#findComment-3809324
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
