  • 1 month later...
Just need some coilovers... then mines not too bad :P Also waiting for my GTR spoiler to get painted and fitted.
More pics can be found here
Looks nice.. Your car is virtually the same as mine now - Same front bar, skirts, same coloured wheels.. Same mods and then me waiting on coils/springs too lol
Cheers Greg,
After a bit of research i learned it was a full top secret kit minus the front quarters with the vents. Its now got Tein Super Street Coilovers, Carbon Intake Pipe, Jim Wolf Popcharger and heatshield, Stainless Extractors and Johnny Spec Twin 2 1/2" mandrel bent zorst with highflow cats and x pipe.
Unfortunately Some lovely fu(k keyed it last week so its booked into the body shop to get the entire passenger side and front bar resprayed... Was so close to having a enough money to order some 20's for it and now this... iggnorant pricks... ah well... ill post some more pics tonight
hey thanks Greg
she is definatly starting to look good................now to make her go a bit faster........gonna be doing some engine work next year aiming to (hopefully) get close on 200 kW at the wheels
with no turbo, supercharger or nos :(
Heres a couple more, looking at some dress 20's for it but next mod will be a kazz 2 way.
Believe it or not were considering a VK56 swap for it... same reason we did blacky originally, the current engine/gearbox combo is worth alot of money here in aus, id import the titan engine and another vq 6 speed manual and adapt it... just researching atm... but its looking good ;)
Hehe yeah.. I ran a 14.32@98MPH with all the mods but with the stock airbox... Pretty sure its quicker with the stock airbox over the pod... But for the time being the pod stays as it gets rid of some of the horrid twin cam resonance it has, putting some extra resonators and expansion chambers in the exhaust over the weekend to hopefully fix that. Its plenty quick enough, but it would just be damn cool a V8, especially the VK56.
ill have to get some 560GT badges made up just to confuse people if and or when i do it :)
marios r33 is f**ken shhhmick! +10 votes for you
i love the white r33's even if there are alot of them around, my old stacked 33 was white my new one is grey....i like white better =/
where did you get your interior done? could you post some more pics of the interior? cheers
thanks man, at least i got a fan haha
ive changed the car a fair bit thou, lowered it more, added the rest of the kit etc, looking shmick
a mate in sydney dun it
im tryin to sell the interior now so hopeing sumone buys its
i will get sum shots up of the trim thou
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
