  • 2 months later...
what wheels are they? look Tarf.
heres my daily as it currently sits too. in desperate need of a lowering, tint and offset defying rims.
However, the above should be a testament. You CAN make an NA look like that. Its still 4stud, just with a turbo driveline and GTSt brakes ;)
Those rims are XXR 002's. 15x8 +0 offset. PERFECT streetable fitment for a 31, you could go a little lower offset if you wanted but they are pretty bang on flush.
Here is some more pics of it I took a few weeks ago:
rb26 head, mis matched cam profiles, wet flow bench porting, CNC cut valve seats, weight balanced valve train, stainless steel 1mm over sized valves with back cut on intake valve, supertech springs and retainers, GIZMO thermal intake gaskets, ram tube manifold i made from 6 tubes and a plate of alloy, spitfire coil pack, 6-2-1 equal length extractors
rb30 block, steel H beam rods (with a 0.8mm hole drilled into the big end for an oil squirter like on the standard rods), "custom" JE pistons tuff coated tops and (teflon coated skirts) torque plate honed to suit chrome moly rb26 rings, knife edged crank, chrome moly flywheel, excedey heavy duty clutch, balanced entire bottom end, king bearings 10.75:1 comp, haltech pro sport 2000, 20 something row oil cooler, arp studs, nitto MLS head gasket
also it helps to work in a machine shop with trade discounts, cost no idea how much but its past 10k easily maybe close to 15k, power not sure yet getting final tune though im more interested in response then HP figures
Edited by Gerg_R31
hey boys, these have been my cars ive owned on my L's /P's (turbo restrictions) so they are all non turbo
this is my first car at 16
2nd car at 17
3rd car at 18
4rd car at 19
5th car at 20
then lost my license 1 month before turning 21 :(
Edited by w34ponGT
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
