Hi Guys,
I'm about to do an oil change on my Series 2 R33 GTS25T, and I've come across a New Zealand supplier who sells Royal Purple oil, now I'm completely stuck on which Royal Purple oil to purchase, they range hugely in price $10-$25
The cheaper oil:
(Royal Purple Motor Oil 10W30 1QT (946mls)
(Royal Purple Motor Oil 10W40 1QT (946mls)
(Royal Purple Motor Oil 20W50 1QT (946mls)
Then you have the stuff which is about $20-$25 per quart:
Royal Purple Racing Oil 21 5W30 1QT (946mls)
Royal Purple Racing Oil 51 20W50 1QT (946mls)
Royal Purple XPR 10W40 Racing Oil 1QT (946mls)
Currently I'm running a Shell Helix 5w40 Oil, so I assume I should go for the 0w30? Or is that to thin? Am I alright to use the cheap royal purple, and is it still good stuff? And which weight should I use? My car is a little loud on idle, turbo is does make some rattley noises. :cheers:
Also I assume i'll need 5 quarts? Or should I buy 6?
Cheers Guys
Edited by dekodE_
https://www.sau.com.au/forums/topic/216172-royal-purple-oil/
To be totally honest mate, I have run Royal Purple in 2 of the 3 Skylines i have ever owned.
Royal purple is a really light oil which barely lubricates the internals thus giving you more power.
They said it increases power...yes...however, they compromise this by allowing the oil to be less restrictive "lighter/not as protective", which in turn allows ur internals to move quicker generating slightly more power.....
I would not use this is my car again... And i am not bagging it out.. I just believe its sh!t and makes ur engine very noisy too...
Hope my experience helps...
If i were you, i'd prob run Penrite "SIN" - Which is 100% Synthetic.... Great stuff :P
OH...BTW - You can get Royal Purple from Autobahn. - Secondly, your car should take anywhere from 4.5L - 5L...I usually put 4.7Ltrs in and run it for an hour around town...usually takes another 100ml.
Cheers.
Edited by SunnyCoast
This line doesnt make sense to me. Metal to metal contact would provide more resistance not less...
Ok - Picture walking through mud...you can't move very quickly can you?
Ok - Now picture walking down the street....
Which one is easier?
The les resistance from the lighter oil allows the internals to move faster. In this case, the lighter oil allows the parts to move quicker, however, because it is lighter, it doesnt give the same protection as a thicker oil.
Understand?
i use it in my gearbox and found it worked a treat. have to get some more soon actually.
The gearbox oil is fine. I just wouldnt go putting this in my engine....Done this too many times and found it to be complete crap.
Cheers.
What do you base "it's complete crap" on? Because obviously you know more than the people developing the oil.
Yes any thinner oil like royal purple will give you more power and probably more bearing wear too - but how much more? Does it shorten the average Rb's life from 300000klm to 270000klm?
What testing have you done and why do you think thin oil is crap?
Ok...firstly learn how to not post twice. You only have to hit enter once (1)... - Thought as an admin you might've learned that by now...obviously they are using monkeys to do a mans job these days...crazy...
Secondly, i had to get a new camshafts (mechanic told me it was the oil i was using, and was backed up by other performance mechanics) because i used royal purple from 40,000km's to 130,000km's every 5,000km's... Now if that isnt testing, i really dont know what is.
Now go shut your hole wang chung!!!!
Thanks :blush:
I don't mean to flame but would a better analogy be a comparison between getting dragged face-first through mud or face-first over tarmac?
Cos it would make more sense; the tarmac MIGHT be easier, though its gonna hurt like hell and make you fugly.
You seem a bit undecided!
I use royal purple in my liner and found its great all round - its not the cheapest stuff around but its supposed to be the shit. The gear oil is thicker than the Nissan stuff but makes everything much smother especially in my gearbox.
If you want real testing and not just 'my engine sounds noiser' there was a test done in street commodores a while back between pretty much every brand on the market, they did some experiment on a bearing and punished it to see which oil would protect it best - the royal purple was number1! With alot of the common brands getting bad reviews.
Back to the orignal post, Im pretty sure its the xpr 10w40 thats in mine
  • 4 weeks later...
If i were you, i'd prob run Penrite "SIN" - Which is 100% Synthetic.... Great stuff :)
Cheers.
Hi Everyone,
As I was searching through google, i cannot believe i was reading this post.
In the least harsh and blunt way possible i will try and explain in detail all the things incorrect about your statement. I am not "having a go at you" i am simply trying to educate you and prevent other people from misinformation. Don't get me wrong i can understand why you thought the way you did.
For a start.....oil viscosities......If a ROYAL PURPLE oil is rated at 5w30 and a MOTUL oil is rated at 5w30 guess what? at the API and standards testing temperatures they are the same viscoscity, one is NOT thinner than the other.....
NOW, for the statement about Royal Purple being "thinner" causing "more engine wear" couldn't be more incorrect.... matter of fact it is the COMPLETE opposite. A thinner oil will decrease wear and decrease friction (within boundaries of manufacturers specifications)... here is a better suited analogy...If you were to run hard cheap tires they have little traction however they last longer (LESS FRICTION), if you used soft compound racing tires you have more traction but they wear quicker (MORE TRACTION).
Now in order to create more power in a combustion engine you need to increase volumetric efficiency (fuel/air mixture compared to total volumetric capacity) or decrease opposing forces, a thicker oil will not pass through clearances well and cause greater friction causing greater wear (similar situation as soft compound tires), however the thinner the oil the greater the lubrication and less friction, they claim more power as the engine is being lubricated BETTER creating less internal friction (which is an "OPPOSING FORCE"). A thicker oil should ONLY be used in a situation were your engine has been rebuilt to something other than manufactures specifications or your engine is suffering from extreme wear (even then ask your mechanic).
HOWEVER, there is a downside to an oil that creates a thinner film, although it lubricates better the film strength is weaker, so under prolonged extreme temperatures it is prone to dispersion of the film promoting engine wear (This is why usually the use of thinner oils employ synthetic esters and oils, that are developed to combat these issues compared to thinner petroleum based oils), however even race cars use a similar film strength, for spirited driving or even occasional track, there is absolutely nothing wrong with royal purple oils. Testing has proved them to be very good.
In conclusion, if you're running a streetcar and running the manufactures standards, you would be lucky to prove a difference between most half-decent oils. A base mineral oil that the local dealer supplies would be more than sufficient. Only in these extreme conditions are these oils needed, or the age-old issue of "having peace of mind" knowing you're using "the best" or something that by far exceeds those standards of what your manufacturer recommends.
About your camshafts, thats bad luck. However I highly doubt it was due to the brand or base of the oil you were using. An oil of the same viscocity regardless of brand (something half decent, Motul, Fuchs, Mobil1 etc) will not cause this much wear. Wether it was Nissan Basic Mineral oil, or the very best Motul 300V (if they were the same viscocity, unless it was under very high amounts of stress or in unusual temperatures, you would be lucky to prove a differance). If it were true it would be due to the viscocity used. Also if it were to be the oil, it would of affected other parts of the engine alot worse before it affected the camshafts.
Also an interesting fact considering everyone here is a Nissan fan (so am i even though i have a Honda) the Volumetric Efficiency i am talking about is in relation to fuel/air mixture compared to total volumetric capacity. A Forced induction engine is technically the only way to push Volumetric efficiency over 100%, all in all a naturally aspirated engine will only be able to run at best 100% volumetric efficiency which is almost impossible without air induction intakes like on the sides of Ferrari's. Thus, where the saying "There is no replacement for displacement" originates.
Sorry about the spelling and grammar, not the best, but I was in a rush and ended up writing a lot more than expected. Hope this helps.
Regards,
Andrew.
Edited by DOHCTR
  • 2 years later...
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
