Hi guys,
I looked up an old adjustable cam gear thread but couldnt find any information about the compatabilitys with the standard ECU.
Going by the post everyone got the best results on the RB25 with about 3 degrees advance?
Is this ok, and will I see any benefit on a Standard ECU? is it safe etc?
Thanks guys,
Bill
https://www.sau.com.au/forums/topic/216356-exhaust-cam-gear/
Hi guys,
Thanks guys,
Bill
Bill,
thats 4 degrees retarded on an R33 exhaust cam.
The standard ecu is ok, there is gain to be had.
Is it ok just to enhance the cam gear for the exhaust half of the engine as its often the most restrictive? I dont want to bother mucking around installing a intake cam gear, Ive heard custom works need to be done most of the time to fit new gears??
I doing the timing belt before I wack on the turbos and shit so thought it would be worth while??
Ive also heard that there is no increase for a r34 NEO ENGINE but I doubt that can be correct, its obvious fact cars are made to beand quiet and prevent detonation with the stock exhaust for regular users. We all change this with big exhausts and so on, so I doubt this can be true. To make it quiet there has to be some restriction and cam gears are an obvious choice.
I for some reason remember DAN666 coming up with this result, I also remember him trying to figure out why his car was not pushing to his target powermark i.e restricted.
Ill give it a go with a cheepy JJR cam gear and she how she fairs, cant give no result, at least it will look hot lol
hi decimate
my R33 certainly made some gains mid and top end at or around 4deg retarded. (seems worthwhile changing to an adjustable exh. cam gear if you are replacing the timing belt since you are already in there)
the neo powered stagea only lost power up top. if you are trying to move the curve around they will do something but if you are looking to make more top end i suspect you will spend money better saved towards cams.
Edited by wolverine
The thread you found was probably the 1 I posted up a couple of years ago from my old '95 R33 GTS-t.
Here is the dyno sheet I posted in that thread:
It cost me about $250 supplied and fitted (back when the yen was about 70) and was the best money I ever spent on the car (altho it was basically stock haha). The extra midrange was noticable as soon as I drove out of the workshop and it felt so much different to drive.
Edited by benm
I've read 10-15kw max power increase. I'd only do it after the main restrictions are removed (intake/exhaust/boost) or when doing the timing belt.
Let us know if you end up doing it :thumbsup:
CRD manage to squeeze an extra 8kw out of mine with just exhaust cam + new belt :D
  • 6 months later...
im thinking of getting an adjustable cam gear (exhaust) ive got all stage one mods done (full 3" xhaust, pod + CAI, front mount, heavy duty clutch, boost controller @ 10psi)
gonna get a safc soon, will a cam gear be worthwhile?
whats the average cost to get one fitted?
cheers
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
