Mclarens just announced that all drivers will remain for 04. Hope DC proves me wrong (PLEASE!!).
Rubens will stay so no change for Ferrari.
Montoya has reportedly signed a not so "secret" deal with Mclarens for 05. I think this rumour will be hotly debated.
JV is struggling to stick around. Someone from BAR may have to make way for Sato and JV's head is looking good.
Renault are also keeping JT and FA. Good combination there.
Massa and Fisi maybe at Sauber next year. Either way I think one of these will one day be asked to fill in the big shoes of schuey when he hangs up his helmet.
Just reading F1 mag and it's very interesting the telemetry of Schuey and Rubens. Schuey like to use left foot braking while Rubens doesn't. At Silverstone, from the corner Copse to Becketts, Schuey is 20km/h (0.15sec) faster out of Copse and when exiting Becketts, has a 25km/h (0.2 sec) lean on Rubens.
  • Replies 91
I'm amazed that rubens doesnt left foot brake - how does he compete at that level without! In touring cars, the only reason not to use left foot is the clutch, f1 and some race boxes dont need clutch so no other job for the left foot.....
I beileve, and I'm trying to remember stuff from when Rubens first started at Ferrari that the reason he doesn't left foot brake is he actually (or maybe used to) use the clutch in some corners...It was some werid reason like that.
I remember it becuase they had to make some changes to accomodate it, and they where discussing it one race a year or so ago.....
3 Races to go.......................GO SCHUMACHER/FERRARI!
I swear to God, Channel 10 BETTER show the Jap GP live if its going to be a Championship deciding Race!!!
I swear to God, Channel 10 BETTER show the Jap GP live if its going to be a Championship deciding Race!!! [/b]
lets hope so, let hope that Ferrari and Bridgestone get thier car and tyres together before this next race cause if they continue like the last 6 races or so the championship is over.
Down with those red cars, i use to be a fan in the Mansell/Prost etc etc days, but not now.
After the Damon Hill, Jacques incidents i have put a bounty on his head. I loved when he put it into the wall (after i realised he was ok) at Silverstone and broke his leg...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
