  • Replies 164
It is such a shame that I didn't see this thread until now. I for one am shocked and dismayed at the negativity towards these poor girls. They are obviously very proud of their beautiful cars and I believe that they are more than likely wonderful people who have great things to contribute to this forum.
Shame on you all.
LOL
rumour is it was the same ip...there was never two people, unless there is a Jekyl and Hyde deal going on lol
2 people, there was 4... :P
it must be roger...
:whistling:
has anyone ever thought that anna, corinne and I might be the same person too?
No, cause ive seen you and Anna in person...
Which Anna? I was posting on msnismos computer that's why we would have the same IP..
But yes.. My name is Anna.. nice to meet you :whistling:
Exactly! Who knows! We might all actually have wangs too, I guess you never really know about these people online. All mostly pedophiles, according to my 82 year old great aunty.
I heard Liz has a big wang :P
I need dinner and clean up a bit around the place while ur at it thanks.
YEEEESSSS!!!! Now make me dinner and do it with your tits out! We'd also love it if you washed our Skylines in your swimwear. This is an awesome thread. Pics too, post them now, If you want the boys on your side, read above and follow what it says.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
