agreed. mounting it in front of of even behind the radiator is not a good plan. it wont get good clean airflow and it will just starve the radiator of air even more. for a 32 GTR the side ducts are the only way to go really. and considering there is bugger alll room on the drivers side most people go passenger side as it's easier.
Actually for the life of me I can't figure out why no one has managed to build a decent oil/water cooler. Makes much more sense than the oil/air ones...
Speaking of oil/water cooler is there anyone out there who has blanked off the stock one?
Oh and my set up is the same as BBGTR's.
there is a very decent oil/water cooler. PWR make one for 32 GTR. Mark and Russ have one in their GTR and by all accounts it works very well. according to Mark they don't see oil or water temp above 100C. and I have seen them string plenty of laps together in one session. :yes: Plus they have big power and would certainly be putting some serious heat into their oil and water.
yes...ive taken all that shit off and run an RB20 filter block (alloy filter mount that bolts to the engine block)
I asked about that system, but I don't want to run a lard arse radiator with unshrouded fans to accomodate it. Plus I have issued a Jihad on PWR after some intercooler bollocks.
There appear to be some other options that bleed off some of the radiator flow & use that. No idea where you would manage to install it in a GT-R engine bay, however.
I have the sandwich plate for the oil cooler so I guess that still bolts up ok to the RB20 filter block?
yes...i still run the oil filter relocator...ive just removed the thermoblock and cooler core from the circuit as its not required for drag. Getting the oil up to temp in the pits before a run was fouling my plugs.
fair enough. I do know from experience PWR can be a bit hit and miss to deal with. they have some nice products though. maybe worth shelving the holy war on paul weel and just give in as it's a known performer. I agree it's a bit of a beast but by golly it works well enough for mark and russ and they are making 150% of the horsepower of most of us, and I know they punt their car pretty hard.
Hey don't get me wrong, I have a completely different Jihad out on Paul Weel after some piss poor performances in an SBR car a while back.....
I continually change my mind on the whole oil/water, oil/air thing. On the one hand it is the best solution from a temp point of view. On the other I hate the thought of mixing oil & water. I have an AU Foulcan 's worth of experience with that.
On the third hand ;) it isn't cold enough to need any heating in normal operation and it is fine for sprints etc.
On the fourth :spank: the oil/air unit doesn't do fk all to reduce oil temps once the car is parked up.
But then again I guess the oil gets cooled indirectly through the galleries..
Oh crap I have a headache again. :yes:
Edited by djr81
DJR,
i have removed the stock oil water cooler and put a remote filter set up in its place, little bit of dickin round with the adaptor for the threads but nothing major.
I have now installed a Mocal oil to water heat exchanger this i have installed in series with the water flow from the radiator into the engine. along with this i have a electric pump in series with the mechanical pump which turns on at 85 degrees. Seems to work well at the momment. Set up required to install quite a bit of extra piping as electric pump is installed in front of passenger wheel, increased the volume to about 10 litres in total. And i need it over here going to be 45 for the next 4 months :-)
the best way I reckon for 32 GTR is as per jenkies one. mine is mounted that way too (it's a trust kit too) and I haven't had any problem with it in 4 years or so of use. one other piece of advice for jenkies is you need to open up the inner guard behind the core so the air can escape. either cut a section out and replace with mesh or swiss cheese it with some 30mm holes.
thanks beer baron its on my list of to do's.... since i bought the car i havnt had a liscence so it doesnt get driven much except around the block to circulate oil. 43 more days to go woo hoo... might get stuck into that rear duct this w/e. so the hot air can escape and flow throught much better....
:yes:
That is one of the best installs i have seen. Its a credit to you or your mechanic. So many people install their coolers in a way to damage them after hours of use hot
Thanks mate; thats nice of you to say. I spent a lot of time on the install.
I agree with the other guys that said the oil will drain back and create an airlock in the system after i turn the engine off, but i couldnt see any way around it. There wasnt room for the fittings at the top, and i wanted to drain dirty oil out anyway. When i turn the key, i get 3kg/cm3 immediately, and then full oil pressure about half a second later. Its a bit of a trade off i think.
Shaun.
No talk about how the crazy japs put the cooler on my car? :rofl:
no lies under 90c at the track, i have both water and oil defi's set with warning @ 95c
they got close but were both around 90!
not to mention that its pretty easy to drain except where they mounted my oil filter thats a pain in the ass.
Edited by Angus Smart
I'm not so keen on your spot andrew. very prone to damage, I also question how much good airflow it's actually receiving there especially considering on that angle it's only showing a very small frontal area.
Yeah i agree its position isnt the best for damage etc tho it is tucked away a little.. and isnt the lowest part on the car.
its cooling seems to be rather good! i was considering building an alloy shroud for it but it kept around 90c at eastern creek on a 26c day
i'm going to leave it for now but if i do hit something its going to be costly.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
