I'm really keen to see some 'stock cams' graphs with the benifits. It's certainly a different way of looking at the traditional and I'd love to know how it's supposed to work. :rofl:
Herein lies the problem.......
Are we racing dynos or cars??
For a few years now , the dyno (ours included) has said that the cammed cars make a slightly better power graph.
However our experience has 'found' that the cars go FASTER with std cams on these little turbos.
And its interesting when you reverse engineer these things (take them out) and don't immediately tell the owner.
You get a response like "I don't know what you did but it feels great and I improved my PB"....
So I guess at the end of the day its a little subjective hence the differences of opinion.
cheers
Tekin - if your going down the line of why a commercial company out there to make money... offers parts other than standard, i think you've failed to see the whole point of the discussion here.
Its like saying why do companies make Neons, 100dB and 90dB exhausts....
Its all about offering a product range that makes money, doesnt mean it offers benefits over and above something else at all.
I think its sorted though, dynos or cars - dynos for you, cars for the others :/
Problem being is that you need to sit down & assess where in the rpm range you want your torque. Basically do a log of the % of time spent in various rpm ranges at 100% TPS. Then graph it. Then use that to determine whether or not after market cams are for you. The larger units (relative to stock) struggle at around 4000rpm which coincides to alot of corner apexes around the country.
Anyway the track versus dyno thing is just another way of saying your turbo motor sucks going down hill....which they do.
...if stock cams where the best for GTR's...why would we have so many different after market ones to choose from.All that time and money from HKS, Tomie, etc etc..is it all a waste.????????.lol
I think you can email them now...let them know..Racepace has decided this and thus it it true.
My statement stands....
The -5's and -7's are small turbos and are very similar to the stock items and as a consequence it has been found that running standard cams provides better response and power on pump fuel (not talking race fuel here).
Bigger turbo's (GTRS's, single TO4z on an rb26 for example) will definitely benefit from bigger cams ie will make more power compared to standard cams, however the -5's and -7's don't seem to respond as well.
The aftermarket (HKS, Tomei etc) is catering for the 'bigger turbo' instances.
A dash five small?
Depends on what you consider to be small, I suppose.
One of these things will flow just over 35lb/min of air. So two of them will happilly give you 700hp, or over 525rwhp without any fancy fuel or much other bullshit.
My set up has 260 degree cams with these turbos. Turned down to 15# (& I mean turned down) it makes good torque all the way to redline.
The upside of the larger cams is less heat through the engine....
We did a track mapping Vs Rpm and found that the high % engine RPM was firmly planted above 4.3k RPM. Which is due to circuit lay out, and most circuits here are F1 standard so not to many tight corners to worry about. I guess in a track only type car we hope to see better performance higher up in the rev range. Also the amount of head work the builder was very keen to see some bigger lumps involved.
I think its sorted though, dynos or cars - dynos for you, cars for the others :(
Ash- It has always been great discussing topics like this one with you over the few years I have been a member. :domokun:
Yes...creating parts for the after market is what makes money for most of these companies.
But in most cases it is justified....take the- stock brakes on a GTR..great but need better for the track...Pads and Discs.
- stock Turbo's on a GTR..great but need some help getting past the line in 13 seconds.
- stock exhaust on a GTR..great but a little restrictive
- stock fuel pump..............great but can't pump too much..especially if you want a great tune.
- can I mention the clutch...5 drops at 6K and the organic crap disappears
ETC ETC ETC.............
Nissan made a car for the people.....in stock form they though it would be adequate for the mass public.
Then N1 improved all aspects to create a race car.....N1AFM,N1Fuel Pump,N1 Block,N1 Pistons,N1 Clutch. N1 Fuel pump..
ETC ETC ETC..............
It is not Dyno figures I seek...KW's mean nothing when a Freight train does not kick in with it.
Cams give you lots of Torque...that is my argument.
And yes..I like to see a bit of rocking when I pull up at the lights.
You have confused the -5's with the -9's
GTRS and -5's have the same housing.....just different turbines'
In some cases - not all, certainly not most.
Lets get back to turbos and cams ye?
Rather than 11ty other things that mean nothing and offer nothing to the discussion here - to which has pretty much been covered i think
RPMGTR builds the cars, archie01 is one of the many.
Good enough for me in the real world
My advice is to change to bigger cams unless your mechanic/tuner/dude that makes your car go faster says otherwise.
I had 260 poncams with my -5's, now I don't...:D
Thats pretty much what I said. Sure there are guys like myself, JagR33, archie01, Soctsman, Aaron34, JFKGTR, RPMZ, etc etc (even R31Nismoid if his car ever see's the road again) all with better results on either -7's or -5's with standard cams in an RB26 - but we've all got the same guy with his own secret little tricks that get them to work the way they do.
My old experience with the poncams was that the beauty of them was all you had to do was fit them and set the cam gears to 0 and you has some pretty damn good results for very minimal effort. So unless you have someone that knows the secret little tricks you are going to get better results easier with poncams there's no question.
cheers
Thats actually fair enough, I was thinking there was some dyno's around showing the changes. In practice though you are most likely finishing the tune off at the track anyway as you would. Who cares about the dyno numbers if you are losing races :stupid:
Really the dyno does it's best to simulate a road going condition but, since you can't simulate accurately a bunch of conditions at speed on the track, you are best off bunging a wideband in and logging/changing away.
I suppose I am struggling to understand why the small standard cams would work better. Would like to get some insight though. :domokun:
Perhaps the cars in question have built motors with flow restictions removed elsewhere in the head? It's certainly true that a higher flowing valve needs less time open to achieve the same volume so maybe there is some sort of wierd pulse frequency thingo going on?
I think your experience is like lots of others on the forum. Cam's are a bit of a mystery. The setting to '0' assumption on the tomei's is common and basically on a GTR a bad one, I've found it to be quite wrong. The assumption seems like it comes from the belief that cams are a cheap mod or at least only as expensive as buying a couple and bunging them in with a slight tune. But, adjustment can take awhile to get perfect.
When I came to these skyline forums I noticed there was a distinct lack of knowledge about cams and how to set them up, I think there has been alot of change since but, there really isn't much understanding in the average skyline punter about the whys and hows of cams (ok so we aren't all mechanics or misguided car-wrecking idiots like myself).
The irony is that I reckon the RB head/cam setup is so easy to tune by comparison to the other abominations I've setup over the years (although I leave room for the idea that I have no idea what I am doing if the stock cam thing is right). I did a cam road tune (adjustable gears) on a young lads skyline today and it took bugger all time to get sweet (not assuming cam timing either). On the other hand helping a mate with his worked up red motor EH was an excersise in me saying at least 50 times 'you know this would have been so much faster if you just dropped an RB in here, it will fit you know...' :stupid:
The thing is even I can setup a set of tomei's or standard cams to work as well as they can using the same basic theory and experience from other types of motors. And I am as dodgy as you get :P I got bucket loads of power out of the tomei's over stocker cams with some mucking around and the car was an absolute weapon to drive compared to a GTR with stock cams adjusted well, with more boost and harder tune.
I think your experience with the -5's and stock cams is really valuable to the forum but, for me being the meddling idiot I just want to find out how :domokun:
Edited by rev210
My Understanding of it all, is that Smaller cams i.e Less lift and Less Duration will make more torque than larger cams more lift and duration, which are aimed at high rpm power.
Torque accerates a Vehicle,
Also as a thought while im thinking about cams.
Do the Japanese Measure their cam duration at .050 thou Lift (when the valve has lifted off the seat enough to actually flow air) or do they just measure total lobe duration to make their product sound cool to the masses.
Lobe Ramp rates have a lot to do with how a cam performs as well, To Sudden a movement Will Kill Gas Velocity, while too slow creates a restriction in the port, Cam Overlap affects Dynamic Compression aka True compression, True compression doesnt start untill both inlet and exhaust valves are seated which may explain why people are getting better results with standard cams over larger aftermarket ones.
Ive noticed there is bugger all technical info on Jap Cams so its almost impossible to choose a set to suit a set up, Take a look through an American Cam manufacturer's listing for cams theye give heaps more specs on the cams and what they're suited for, with the jap ones its look through a magazine and find a car that makes BS horsepower and copy what they have done.
Everything can affect what cam to choose - Intake Runners, Head work, valve size, target peak power and torque RPM's < probly the biggest factor in choosing a cam.
If I change cams in my car (RB25) Ill get custom ground ones over anything ive seen avaliable off the shelf.
Soz for the long post, Its Saturday and Im staying In :-/
Regards
Andrew
I think Zebra has hit the nail on the head. Smaller duration camshafts have better dynamic compression and there is no better mechanical way of getting a turbo to spool than compression - hence incresing torque and throttle response. The other advantage/disadvantage of the 26 is that it has a tiny stroke and rod length so the it lends itself to being reved and not hanging around at TDC for too long this is why the timing numbers are so large even at large boost levels.
With the -5 there really is that much more power to be made above about 22-24psi of boost on a standard displacment 26 and at those boost levels on standard cams I've seen up to 16deg total advance which to me is just perfect.
I think it must be something other than the compression idea, as advancing the intake cam timing and does this along with higher lift. The tomei 9mm lift units smack the standard cams for cranking compression and they smack them very hard, so it's probably something else.
I wouldn't mind having a crack at the standard cams again but, I can't really see a reason to do so given my experience so far is when setup correctly the tomei's maul them everywhere. I'll probably only try if someone can give me some timing points to try and some reasons why to try them . I admit I am being a bit cheeky in asking for what might be a 'secret' :P
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
