Hi fellas - hope everyones well :banana:
Well finally we have started running again & great to have a full year ahead to work on the car nowsmile.gif
Spent the whole day testing doing nothing but working on clutch set up & launches & really started to pay off towards the end of the day with the last 3 60 foots being 1.26 then 1.18 then 1.17 which is great (best last year after the car was finished being built in august was 1.29). Still think we can get that down further to around 1.02 - 1.05 with more work/knowledge & further runs & more datalogging info.
Determined to work slowly but methodically this year ticking a box off at a time rather than trying to rush things.
wont even look at turning the power up until we start getting consistent launches first.
piccie below from the day & start running in anger in 2 weeks - cant wait
Cheers John
Edited by R33draggtst
https://www.sau.com.au/forums/topic/216889-project-gtst-2008/
Thanks adrian,
Great weekend for the car this weekend, really warm with track temps 45 degrees,
whole focus was purely to get some consistency to start with instead of worrying about power & really getting there now 8.51, 8.44, 8.39, 8.31, 8.30 all on 1.6 bar boost.
Turned it up to 1.8 at the end & 8.29 with the car going very sideways towards the end (.6 lateral g ) which meant i had to get off the throttle for 1 sec which cost us time.
Run again in 2 weeks - really looking forward to getting back in her now
Looking very nice, John!
the cars can, most guys who drive them get a bit confused when the car isnt pointing straight. Adrian is a good example, you should have seen him in my go kart, very funny. good luck with the stup mate.. power sure is not a problem.
:spank: who said drags car cant drift :P
A race track is no place for corners. thats my excuse anyway cause i was terrible.
Awesome weekend for the car even though the last 2 days were rained off :(
Qualifying Fri/sat with eliminations starting Sunday pm
Friday we had 3 runs 8.11 @ 166, 8.14 @ 165 & 8.16 @ 170 & lay 2nd in qualifying overnight
Sat crap first run with me asleep 8.6 @ 173 another 8.14 @ 166 & then we said ok got the consistency up the boost from 1.8 to 1.95 for the last run.
We were lined up against a 7.7 sec Ford probe which has been around for a few years & a bloody good driver so my backside was twitching a bit :wub:
Both got cracking launches (his 1.12 & mine 1.15), halfway i'm 6/100ths behind & then at the 1000ft mark whoosh i get a windscreen full of water from a split hose, engine off straightaway, gearbox in neutral expecting the back end to bite but thankfully the water went up & not down so glided to the end of the run @ 8.14 @ 148 mph. The other car completed at 7.8 @172, worse case we might have slipped to a 10th behind him if we had a clean run.
car was fine, no issues with water temps so new hose sorted for the sunday & bugger rained all day so no racing then today rained all day so no racing :) - have to wait 4 weeks now for the next one.
So 5 8.1 runs out of 6 over the 2 days which is great & really chuffed with the consistency.
Hope to carry it on & at least when we do get into the 7's we should be there consistenly.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
