Quick question... i searched and found that i need to space the CAS if i remove the cam cover, but how much????
(basically i'm getting car tuned again, as i've just had poncams fitted, and can now tune the cam gears - so for ease and less fiddling around on the dyno i will keep the cover off...)
thanks
-Matt
https://www.sau.com.au/forums/topic/217178-cas-spacing-how-thick/
Just measure the thickness of the timing cover including the rubber insert. That is your thickness.
If you just use a 3mm washer or spacer you will be fine. It doesn't matter if the CAS is a tiny bit out from it position as there is no load on it and it will still turn in time with the camshaft if it was 0.25 or 0.5mm away from home.
You just need to make sure the CAS does not foul on the cam pulley and also make sure the CAS bolts don't foul either
push the rubber out of the timing belt cover and put it behind the cas
in that rubber there is 3 metal washers which space the cas to factory spot
+1
but i would probably split the rubber off the spacers as there is nothing holding the rubber in place with the cover off.
  • 2 years later...
quick question, have searched etc..
anyone know the length of rb26 bolts that hold the CAS on? the 3 of them?
just wanna make sure the ones i got arent too long and are gonna hit the cam gear.
cheers
  • 9 years later...
Just to clarify for future reference, having gone through all of this recently due do the previous owner of my car loosing all of the bolts and spacers.
Spacer: OD=12mm / ID=6.5mm / THICKNESS=5mm (measurements taken from new Nissan P/N 13525-58S00)
Bolt: 6mm dia. / 1mm pitch / 15mm length.
I'm using some OEM 25mm bolts with the integrated lock washer and flat washer (common mounting bolts for things in the engine bay), which leaves me with 22mm of exposed thread. When installed into the CAS I can see 2-3mm protruding towards the cam gear, but there's 15-20mm of clearance before it hits the cam gear.
Cheers
  • Like 4
Cheers
Just realised a typo in my previous post. I have about 4-5mm protruding through the CAS mount and into the area where the cam gear is (NOT 22mm!).
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
