Eoi: Greddy, Cp, Arp, Garrett, Cometic, Tomei
Hi all,
I have a friend in the US who has just started a website selling performance parts for everything "RB"
www.rawbrokerage.com
Im gathering some interest for a group buy on some items he is selling.
Greddy Plenums
Garrett Turbochargers
CP Pistons
ARP Bolts
Cometic Gaskets
Tomei
The more i can order the cheaper it will be. I dont have prices at the moment as we are seeing how much interest we can get.
But if you go to the website all the parts on offer are very cheap,so only further reductions in prices can be had in the group buy.
CHEERS
  • Replies 40
If you are rebuilding an engine or doing some extensive engine mods,you need to look here first as i dont think you will find anything cheaper.
Poncams group buy sounds good.
However it is very important you know which type suits your car as i have a series 2 which was built in 97,the CAS change happend in Sep 97 and i ended up buying the wrong ones :D
All pre Sep 97 builds require the "series 1" type cams,even though you might have a series 2. Confusing i know.
RB25DET that is.
Ill get onto it and let you all know.
Thanks for all of your enquiries!
Turbocharger prices are now up: Garrett Turbochargers modified by PTB Precision Turbos (America) Modification is only to compressor.
GT28RS - $1496 Delivered
GT3071R - $1496 Delivered
GT3076R - $1545 Delivered
GT35R (GT3582RL) - $1612.50
(Let me know if you need any larger turbos) (These are all externally waste gated.Internals are $75 extra)
Also offering PTB Precision Turbo,Turbochargers.These are quick response journal bearing turbochargers.
SC50 450-460hp - $983 Delivered
SC60 580-600hp - $983 Delivered
and on up depending on what the power goals are.. ~$1210 for them. Delivered
These prices are at 3 or more so i will need 3 orders to get them at this price.These are in AU dollars and are excluding shipping.
I will get a shipping price on 3 turbochargers very soon.I will only place an order when i have 3 orders from you.
Look forward to hearing from you. :cheers:
how much for a garrett gt3076R with a .82 4bolt exhaust housing.. t3 flange, externally gated?
cheers :cheers:
Im pretty sure LTHLRB is reading my mind lol. .. And Sheng too i see lol
very very interested in the same turb if the price is indeed only $1452.50
also interested in greddy intake plenum to suit rb25det.
When is the group buy happening. Like when do we need to pay??
EDIT.....i must be blind. for sum reason thought u guys had written gt3582 haha. my bad peeps, ignore me lol
Edited by tm_r33
hey mate i was looking at the prices on his website.
the price he has on the gt28 on website is cheaper then the price he gave you.
for the gt3071R its the same as the website.
try n see if u can haggle better price then his normal pricing for multiple purchases.
Edited by tets
Those website prices are in US dollars mate.The prices i have posted are in AU dollars.
i know mate i used a currency converter
your price was
GT28RS - $1336
GT3071R - $1336
on site it is
GT28RS 1,131.12USD = 1,208.38 AUD
GT3071R - 1,250.99USD = 1,336.43 AUD
currency exchange rate used is 0.936067 so i might be a bit off.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
