otherwise, do it jap spec:
looks so easy!
hahahah... as funny as it seems... the best way to do this is with the heat gun and a plastic hammer... but I need somone willsome skills.
  • Replies 131
yup... athid ROLLED mine... flaring is much more likely to crack paint...
he'll reply sooner or later...
Thanks fellas... ah... I don't wanna roll mine as my rims fit nicely and there's no need to roll them... however, I just want a small flare nothing much... but I don't want to crack the paint...
Oh well, I'll just have to wait until Athid responds... would you have his email mobile number by any chance?
Cheers,
He's overseas at the moment as far as I know. Not too sure when he'll be back though.
Edit: To flare, you'll need to roll. With flaring, you're just rolling the guards, but instead of stopping, you're continuing to push out the guard which creates the flare look. Unless you're wanting to pull the guard out from underneath and pull it out...
Edited by adam-__-
i was told that the chance of front guards cracking paint from flaring is pretty high, especially on the straight edge R32 shape.
so to tackle a really bad scrubbing problem (after i got myself some camber for the fronts), i changed the fronts from 235/45/R17 tyres to 215/45/R17.
no more scrubbing, and i got some stretch which suits the back stretched tyres :blink:
If they stick out,you have the wrong offset. I have 10.5 wide on mine an the dont sit out the guard.
Looks nice though.
No such thing as a 'wrong' offset. Depends on the fitment and stance you want... and if you actually want your car to look good.
Having flared guards without the wheels to fill them would look pretty strange and imo homo.
Actually, this did cross my mind....
Does anyone have pictures of a R33/R32 with flared guards?
hey spunky are you planning on fatter rims?
Hey bud,
Nah, not fatter dished rims... just what i got, 18 inch deep dish... i just want the back to slightly flared a bit only...
Also, the above pics looks like fb add-on guards... don't want this, i want it done in subtle manner.
What about flaring the guards before a respray? Or can the paint still crack?
Is that flared guards? Looks like widebody judging by the petrol cap! How much would something like that cost to get done? Looks awesome!
Edited by cosmokram3r
Cracking only occurs when/if you don't heat the paint up enough/too much or are pulling/stretching the guard out too much. If you got the guards flared before the respray, there's nothing to worry about.
I wouldn't say that's "flaring". This is what I see flaring as...
Obviously flaring and some extra work done to it to make it look a little better.
Flare people normally go for.
Edited by adam-__-
Looks nice though.
No, thats where you're wrong. IMO, if they DON'T stick out you've got the wrong offset. Wheel fitment will make or break the look of a car. Nothing worse than sunken wheels.
Contact Primal Garage in West Footscray, they specialize in this sort of work on Japanese cars. They'll be able to do it no worries. If I were in Melbourne i wouldn't use anyone else.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
