www.finalinspection.com.au
Only place to get your ride detailed.
Damain is probably the best IN THE WORLD, and there is not a business like his in the country.
also, check out
http://www.detailaddiction.com.au/forums/
also, check out
How are they price wise?
Well, they are the best.
Are you looking for the best job, or the cheapest?
They are actually VERY well priced considering the quality of the job they do.
Depends on whether I can get the best done for cheaper :happy:
A rough indication would have been nice.
the proverbial "no brainer"
Damian and the boys at Final Inspection. End of muthaf*cking story.
Don't even CONTEMPLATE anywhere else, because these guys are practically the same price as comparable "detailers" but provide a level of service completely unmatched by anyone in the ENITRE SOUTHERN HEMISPHERE!!! I say 'southern' because there is a freak of a detailer in the UK by the name of Paul Dalton. He does some ultra impressive work as well.
I believe a Stage 1 detail is around $200, (don't quote me on that). But it really, REALLY, depends on the condition of the paint.
If people post up some pics, i can give you an idea of how bad/good the paint is. Full sun shots preferably
dunno why everyone says this final inspection place is the best? as dezz said, unless you've used every other detailer in melbourne/victoria you cannot compare! i've never used final inspection, and i don't doubt they are very good, but i can't comment on their work as i havent seen anything.
all i know is i paid $220 for my detail, and now my car looks although its ready to be taken delivery of for the first time out of the showroom. so i'm very happy.. but i won't go as far as saying they are the best, forget everyone else! that is just ignorant!
if you followed the progress of the construction of Final Inspection's Auto Boutique in Brunswick, seen Damian's work, read about detailing and learning about the best products, the best techniques, what to look for in good results, what corners can be cut, what are the common pitfalls, what are the band-aid approaches, what are the tricks supposed "detailers" use to create "good" results, the bullshit that is found in any industry (5 star shine). When you hang around all this and the detailing forums, and try all the products, see what everyone around the world is using, their results and their processes, you'll quickly realise that Final Inspection has no peer in Australia.
A car straight from the showroom has the potential to look a million times better than how it's presented when you buy it.
is your car metallic Ruffels? got any full sun shots?
ohk, fair enough.. still think its a bit ignorant to assume one person is the best... chuck out the rest.
yeah car is metallic, however i havent taken any photos yet, car is under dust cover in garage, will take some good photos soon and post them up
Around 200 bux is fair, what does a Stage 1 detail include though?
I'll be getting both my cars done at FI, and take my mums car there to fix up the shltty job the place she just got it detailed at did...
I haven't used anyone else for a detail, but if I'm happy with the work of the one place, why not recommend it? *thumbs up*
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
