hey guys. just bought a cefiro, with a rb25DET, but still with the rb20box. its starting to make a few noises.
just wondering what my options are, i guess a rb25box would bolt up nicely, but how about a vg30box? any stronger? just wanna be prepared for when the rb20box breaks.
https://www.sau.com.au/forums/topic/218175-strongest-gearbox/
The VG gearbox would probably just need an adapter plate or something of the likes and will hold up to about 450hp, it has fairly beefy internals similar to RB25DET box afaik but I believe the RB box would be slightly better. Also, the only difference between turbo/na VG boxes is the TT flywheel is slightly larger.
GTST, GTT, GTR and VG30 are virtually the same box, the GTR is only stronger as the output shaft has more support bearings due to the transfer case... therefore recieves less off centre loads.... internally identical to GTST... i mix and match parts a bit. R34 GTR is getrag totally different. R34 GTT same as r33 only has a few niceties inside but no stronger.
  • 3 months later...
  • 1 year later...
So, are the internals from a R33 GTR interchangeable with the R33 GTST?
yeah i have interchanged gears and syncros between these two boxes (second and third gear), amazing how the GTR box goes for less then the rb25det, its the same!
the late model r33 gtr box has a thicker input shaft in places, so a few of the bearings are different. i didnt swap this over but it also looks straight forward
dont be scared of manual boxes they are pretty easy to do, just need the right tools, auto boxes on the otherhand NFI
hey shoei
got a link or something with a step by step on how to dismantle and assemble a rb box?
i have tired to take the gears and syncrhos out myself but got stuck as the gears and/or syncrhos would not come off
thanks for any help
http://www.300zx-twinturbo.com/cgi-bin/manual.cgi
give it a shot, and let me know how you go, i messed up my first rebuild, third gear had a vibration after i put it back together, best thing is you got noone to blame but yourself
Edited by shoei
thought the 25 box was 1 of the stronger ones, bolt up with decent clutch u'll have no probs
the vg box is very similar to the rb25 the only thing that wore on my rb25 is the synchrons (didnt like my gear changes lol) stronger boxes are the gtr and ive also heard that supra boxes are very strong too
correct me if im wrong don't supras and r34 Gtr have the same box ? a 6 speed getrag
wow didnt know that makes me want a rb25 even more ..
so Mr URAS how much rwkw can a rb25 box take then ?
use a rb25 box for now.
you can safely run about 300kw's at the wheels with these.
their are 2 at the track with 320kw plus with a rb30 bottom end and they are holding up just fine.
not sure how much further you would go though, once your going more than that save up for a pdg gearset or simular
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
