I just took my 1 week old black R34 for a good wash ... I was aware that there are a LOT of fine scratches and swirls on almost every single panel of the car (seems the japanese owner used those dodgy drive through car wash places a LOT :D( ) so I bought some Meguire/Autoglym product to try and do a detail myself ...
After a good wash with Mequire's Gold wash I came to realize the paint is in a worse condition that I thought ... esp. the roof and the bonnet.
There are so many frigging damage spots (1-5mm sq. spots of cracked paint ... oxidation? salt? acid rain?) where the paint is completely gone and all you see white cracks and the metal body in the centre. So after the wash now, what I thought were tons of insects and bird droppings turned out to be damaged paint that no shampoo or wax is gonna fix :)((
Can anyone tell me if it's possible to have just the roof and bonnet resprayed and my approx. costs? The car is factory black (GV1?) I'm in sydney ... my dad's mate's son does car spraying for a living so he might be able to do it a bit cheaper hopefully. I definately don't have $3-5k to respray the whole car :D Even though there are a few scratches and damage to the doors, boot and other panels they're very minor compared to the roof and bonnet.
I'll try and take some pics later of the roof .. it looks horrible from a close distance.
The only good news is that, like any black car, it still looks farken awesome from atleast 3-4m away (when you can't see the paint damage/surface scratches) !! ;D
https://www.sau.com.au/forums/topic/218220-respraying-roofbonnet-only-possible/
I'm sure a cut a polish will take care of the fine scratches/swirls that are unfortunately on every single panel BUT .. as I said, the roof and bonnet have a lot of paint damage that nothing can fix (it's clearly cracked paint with undercoat visible)
I'll take some piccies and post them soon...
From what you've written... e.g. white areas that have cut through the paint etc... I think a cut and polish is useless, you'll need a respray... to answer your question, yes, the bonnet and roof can be repainted.
I had my bonnet repainted... and asked about the roof too... both can be repainted... you'll be up for around $350.00 for each... there abouts.
my car has had the roof and bonnet resprayed and blended down to the 1/4 panels
but i got a massive discount....
should have been about a grand i think
Mate, just my 2 cents... but if you paint your mesh black (or get black mesh) for your car - it would make it look much tougher.
And yeah, for the two items as I noted, $700 at least.
$700 normal rates or mates rates? :thumbsup:
Either way I reckon it'd be a worthwhile investement as the roof and bonnet are truly fuxored ... the rest, can be hopefully fixed up with a cut and polish
Hey mate, $700 would probably be the middle ground you'll expect... you'll get quotes from anything like $1,500 through to around $600 so I guess $700 would be a descent price for a good job - it will take a few weeks do get finished... as your roof will take the most time... they'll have to slice it off at the sides of the panel etc.
Yeah, it is a good investmen... the other small things a cut and polish would do fine.
Good luck mate.
Good luck mate.
That surely must be a joke?? ;D
Edit: wait you can't really be serious ??? few weeks for a $700 job?? CUTTING the roof off ??? wtf? why would they do that .. they can just spray it on there. you MUST be joking right? riiiight?
Edited by Delta Force
Mate, relax!! He doesnt mean actually cutting the roof off, he means cutting back the paint, painting it, and then blending it back onto the car. Your car isnt about to become a convertable :thumbsup:. And yes, it should take a few weeks. You need to let the paint cure, as well and the primer and clear. Good luck!
It shouldn't take that long to paint a roof at all .If I was doing it it would be a two day turn around the only reason it may take this long is it would be a job that gets done in between insurance work which is understandable .
Paint dosn't take long to cure enough to take a car home .A car can come out of the booth in the morning and the owner should be able to take it home later that day .
If the paint on the roof is as bad as it sounds then the yare going to have to prime down the pillars as well so they will have to paint the rear quarters as well .
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
