in about 3-4 weeks im after a 3076R :) hehe
When you are ready PM with the exact spec of GT3076 you are after ie: CHRA number,A/R,flange type and internal or external gate.
CHEERS
with the 3071 can you get it with a rear housing that bolts staright up to and rb25 dump pipe or are they all 3" 4 bolt flange?
You can get the 5 bolt internal gate housing but you will still need a new dump pipe.
As the turbo is bigger,you cant be sure that the dump pipe will line up 100%. The biggest housing that bolts straight on is the 0P6 housing.
garret make a housing that has the same dump pipe flange and from the research i have done it will bolt up to the dump just need a 10mm spacer between the turbo and manifold.
http://www.horsepowerinabox.com/hpiab2/category12_1.htm
NEW!! RB Nissan Special Garrett GT3071R ball bearing turbo
At last!!!! An All New unit option for RB20/25 Nissan Engines with the compatible T3 base flange and 6 bolt Nissan Dump Pipe for a complete bolt on solution in a Garrett Ball Bearing GT series turbo.
This new casting exhaust housing can be machined to suit this turbo (GT3071R), GT28RS, GT2871 or GT3076.
** please note the Garrett GT series turbos have a M14 water outlet size rather than the larger Nissan RB20/25 size outlet so water lines will have to be revised**
  • 2 months later...
GT3076R 5bolt internal waste gated
1,345.00 USD = 1,567.51 AUD
(1 USD = 1.16543 AUD)
+ $150 AUD for shipping
Quote includes wastegate solenoid.
THIS PRICE IS FOR 5 DAYS ONLY AS THERE ARE ONLY A VERY LIMITED NUMBER OF THESE IN STOCK!!!!
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
