  • Replies 55
guys
price for following items
starter motor $100
front reo bar - $50
Clutch master cylinder - $60
Clutch slave - $45
Speedo cable - $70
Seat belts - $50 each one (have both front a rear)
Steering rack - $200
Adj tie rod ends $150
thanks
Guest autoas
hey guys im wrecking this r32 gtst. im located in brisbane and all parts listed are available plus many more just sms or pm me what parts you want. the car is complete so everything is for sale. contact make on 0423 849 355
ALL GEAR WAS PUT ON IN JAP SO ALL QUALITY PARTS!
Genuine Dmax Carbon fibre bonnet VGC $1000
RB20DET motor with SS manifold 120 000 kms absolute perfect condition blows no smoke 114 000 km (major service done 10 000 km ago) $1300 (no coil packs) will seperate ss manifold
Front Tein Ha series coliovers $450
Rb20 Gearbox VGC $450
Short shift kit VGC $150
Dash - perfect $200
GTR Replica front bar $150 one mount has to be re fibreglassed on no biggy
Fuel tank $150
Door cards perfect condition $75 ea
Front switches $75 drivers 30 passenger
Sparco Steering wheel $50
Turbo Timer $50
Windshield $150
Front seats $150 Pair
Roof lining $50
Front guards $120 pair
Headlights $80
Indicators clear $80 pair
split fire coil packs $400
HKS split dump front pipe and exhaust $550
Tension rod bar $120
Solid pineapples $100
2 way lsd and housing $750 (brand unknown)
Hicas lock kit $150 ( full replacement kit for lines and everything)
GTR brakes (so i am told will confirm when i pull car apart) $700
Castor arms $150
Doors Drivers(some damage) $125 passenger GC $150
K&N pod $50
Viper alarm system $80
PLUS MUCH MUCH MORE! just ask and will pm or sms! thanks heaps will have more photos and a video of the car running as it is in perfect condition when computer isnt being gay
Mike 0423 849 355
post-17389-1210394305_thumb.jpgpost-17389-1210394407_thumb.jpgpost-10298-1124278144.jpgpost-17389-1210394659_thumb.jpgpost-17389-1210394843_thumb.jpg:
gday mate just wondering how much you want for intercooler kit
cheers aaron
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
