poly is a 2 part and once it sets it will burn, but not melt.
You need to buy a kit but i have no idea where you could get automotive grade stuff. There's plenty of hobby type stuff about but it is way too far up the scale to be useful as a bush
https://www.sau.com.au/forums/topic/218815-bushes/#findComment-3860292
There are a number of castable polyurethanes. Normally a 2 part mix and not hard to use.
I have made a few rollers and such before in the backyard.
Getting the right spec poly may be the tough bit for bushes.
There is a mob in Armadale (yes WA Richard) called APT (Advanced Polymer Technology) who may be worth a call or ERA Polymers who are a supplier of polymers.
Cheers
https://www.sau.com.au/forums/topic/218815-bushes/#findComment-3861929
In simple terms, suspension bush quality polyurethane is a multi part mix, climate controlled environment, exact quantities, accurate baking oven for controlled temperature and time. The formulas for different duros (hardness) are proprietory.
I have made bushes in the past from a slug of polyurethane that is lathed like wood, you "cut" it, you do not "machine" it like metal. I haven't had to do that for years, there are so many sizes and shapes available I simply haven't found it necessary to make them. If you want to send me the measurements of what it is you require, I have the dimension data from all of the bush manufacturers, most times I can find something that will do the job.
Cheers
Gary
https://www.sau.com.au/forums/topic/218815-bushes/#findComment-3862271
Thanks gents for the help.
Duncan:
Used nylon on the last set of bushes I had machined up. May do so again as it works a treat.
Wayne:
WA you say. Wow.
Gary:
Drawings and photos attached. Note that the bearings listed were removed from the arms, hence the need for bushes (I didn't want to use bearings). I was thinking that a washer behind the centre sections may help the bush live a longer life.
From trying to get poly machined (bored actually) before usually it comes back a bit of a mess. Not confident that it can be done & retain proper dimensional control. Anyway, hopefully it wont come to that.
Cusco_arms.PDF
Bushes_for_cusco_arms.PDF
Edited by djr81
https://www.sau.com.au/forums/topic/218815-bushes/#findComment-3862804
Duncan:
Wayne:
WA you say. Wow.
Gary:
I am not at my reference PC to check until tomorrow morning, but my guess would be that the step in the bush (where the bearing used to sit) is an issue. I suspect that we will find it easier to find a bush if you say wrapped 12 mm wide x 2mm thick alloy around the bush end to consume the space. Then the bush itself would be a straight 36 mm.
Cheers
Gary
https://www.sau.com.au/forums/topic/218815-bushes/#findComment-3863082
Duncan:
Wayne:
WA you say. Wow.
Gary:
Takin the piss Richard - I know how hard it can be to find something different when you are stuck in the boonies. I mean you could go down to Bunbury Plastics or then again maybe not.
How's the t/case fix going?
https://www.sau.com.au/forums/topic/218815-bushes/#findComment-3863331
Yeah, I know. But last time I went down to *insert name of random plastic shop in regional WA so as to not violate forum rules* they weren't very helpfull. Had the last lot of bushes turned up out of nylon by the machine shop next to Adrenaline. May end up doing so again.
Transfer case may be ready either next week or the one after that.
4WD controller turned up yesterday, so atleast something is going right.
https://www.sau.com.au/forums/topic/218815-bushes/#findComment-3864830
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
