Getting a gt2860rs for my rb20. Pls help me choose the right exhaust housing.
I lean towards the .63, to help with the spool up. I think dispopotato3 said, that garrett engineers made the real gt2860rs with a larger exhaust and comp housing on purpose. So u could run more ignition advance in the low revs. And to free up exhaust flow at the high revs.
Need your input!
Thanks!
Hmmm. I've been looking into nissansilvia forums. And most of the guys run .86 turbo housing. And they get full boost at around 4000rpm. Confused again. Final: .63 or .82 ? Which one will yeld better results ? Still want it to be drivable, but don't want to loose the rb20 hi revs also.
Full boost at 4k for the .86 sounds about right, though to put it perspective a GTRS will make 1.4bar at about 4100 on an SR and make another 20rwkw over a disco as well.
I just got deja vu. I'm sure i've written a near identical response somewhere else....
You're better off with the smaller one. Note that HKS only make the 2530 in a .64 as well. It's virtually the same turbo as a disco except for a very slight trim difference on the compressor.
How much power are you after? How much bottom end are you willing to give up? what are the intended uses of the car?
Normally i'd say go for the smaller housing but as of late i'm more inclined to say since its going to be gutless down low you might as well make sure it screams up high...but as mentioned it boils down to what you want from the car...
The only purpose designed T3 flanged GT28 turbine housing for that NS111 turbine is the HKS one found on 2530's/2535's 2540's and GT-RS's intended for RB20 and 25 . The A/R ratio is 0.64 , Garretts 0.86 A/R turbine housing was only ever made with the smaller T2/25/28 flange .
If you can find a GT2530 kit from an RB20/25 it would be easiest .
A .
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
