Maybe I will start a thread on oil pumps :(
Anyway - to look at my original question about the blocks.... what is it that hurts them?
I have a block that came out a car that would have not been making much more than 300kw. Block cracked between the waterjacket and the bore number 2, filled the bore with water (at revs), and ended with a piston sized hole in the side of the block....
It was a stock motor that was obviously leant on. What a way to go though... BOOM!
:P
I'd imagine there would be quite a number of big RPM launches behind the car that split the block around that point :)
How many R34 N1 engines fracture oil pumps?...none that ive heard of...why not?
well balanced engine with good quality fresh balancer on the front.
its harmonic crank vibration that kills oil pumps...the higher the revs the worse the problem.
id spend the extra $600 on an ATI balancer and stick with your N1.
this is free advice from someone who has done a lot of work, testing and research on this very issue. At quite a bit of expense.
i dont know of many r34's but i have heard of N1 r33 with smiliar problems.
why not spend a little extra for better peace of mind.
rob82 standard r32 oil pumps are weak as
Are you saying that because the r32 have the small oil pump drive or because you geniunely know that the pumps are weak? So R33 GTR oil pumps are fine?
Well, now you have.
R34 N1 motor, straight from Nissan, 15,000kms on the clock, cracked crank journal in the N1 pump.
Still have the pump sitting at home if you want pictures.
im sure the N1 oil pump is good, i neva said it wasnt
all im saying is if ur going to rebuild ur engine and u have ur engine in piece's ur beter of spending that little bit extra and getting some thing better
this is coming from some one who runs a custom machined CNC stainless billet oil pump which has been heat treated
alot of research went into this oil pump the 1st one machined up had some problems with the valve staying closed but with more researching and testing we got it right
I haven't heard of ONE pump failure among anyone here in Vic i know using them.
Being most of them DONT do big RPM launches and mainly track work or street... all of them have been totally fine.
Some of the users that posted here over the years about their failures were as Paul said... people with built "some" parts, and untouched 15yr old others.
And also a fair number at the same time were doing big launches @ the drags etc.
I've never seen a legit reason among many cars here to say a N1 isnt upto the task for moderate power ups.
Only people posting here without any idea of what thier build included or how they drive/treat the car mostly
and probably were wearing 13-15 year old rubber balancers on them that were doing little more than helping the belts go round on the front of the engine.
So many engines rebuilt with dodgy balancers slapped back on them without a thought.
I raced for over 3 years with an N1 at over 8500rpm not a problem. Engine was built by me and properly balanced with a new harmonic balancer fitted.
They are not indestructable but if engine is properly built and ran correctly they survive fine in a street application.
Yes the Tomei pumps are good...out of the aftermarket the Tomei and JUN are definately the pick of them.
I agree with Paul, we must have used over 30 N1 oil pumps over the years and not had 1 single falilue. Why not us? Carefull balancing of the engine and a decent harmonic balancer are the only answers I have as well.
Cheers
Gary
You can break ANY oil pump in an RB if you try hard enough!
We have broken them all... Jun, Tomei, HKS, N1, and standard ones too.
99.5% of the time it's due to the loose nut behind the wheel.
If you continually smash it on to the rev-limiter and it will break the pump.
If you are unsure why it broke (as no-one ever thrashes their new engines!), have a look at the drive faces inside the gear.
Tell-tale sign is wear on the driveside AND non driveside of the gear....thats what the rev-limiter/launch control does!
cheers
cheers
thats how we finally broke ours...3 years of flogging it to death was not a problem...it was when we changed the set-up to a ignition cut launch limiter...it broke on the 2nd pass.
Cheers
Gary
http://www.skylinesaustralia.com/forums/Fa...view=getnewpost
for the record the roundy roundy bits went outside because the bore filled with water.
I will post a pic tomorrow of where the water came from...
lol worst or most?
btw I don't think a n1 block is able to keep roundy roundy bits inside when they let go any more than a standard one is :P
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
