Hey guys i was just wondering where you get your skylines serviced, in particular gtr's? I got my gt-t serviced at unley nissan and they did a good cheap at a decent price but was just seeing where other people went, im sure this has been covered before but couldnt be bothered searching! my car had its 50,000km service done in japan in november last year so looking for somewhere to carry on with the logbooks from then. any advice would be greatly appreciated, thanks
https://www.sau.com.au/forums/topic/219209-servicing/
Like many have said, a genuine nissan service will give you a good logbook, but you'll pay thru the nose. There are some great 'tuner' based mechanics around, such as Boostworx and Tillbrooks, however for my money I go to Road n Track (Gil Camerons workshop), as I've been with them for a long time and they've never let me down... theyre close to me (tillbrooks is closer) but I've had nothing but top service from the guys at road n track. Theyve done a lot of street machines, sprint cars, exotics and their fair share of imports too... the guys who work there are really into the job, most of them race either sprint cars or targa tassie, couple guys do the adelaide classic.... if any of u guys have heard of charlie kovacs, his car was built by these guys..
Going back there in a month to get a stupid amount of stuff fitted. ECU, cam gears, gauges, clutch, gearbox, fuel lines. It wont be cheap, but it'll be cheaper than some, and Im really happy with the tunes that Ive gotten there. Check my sig :P
-D
https://www.sau.com.au/forums/topic/219209-servicing/#findComment-3866671
if you want to go by the book and get ripped off (most places) go to the dealers, if not theres plenty of other mechanics who would do services for a lot less boostworx, tilbrook, hitech dyno tune these guys work on jap imported cars every day
hope it helps
https://www.sau.com.au/forums/topic/219209-servicing/#findComment-3867227
For known quality service go to known workshops like ones mentioned in this thread... for pretty logbook and having your car worked on by f**k knows who go dealers.
I personally do what I can and what I cant I take it to any known workshops that can get the work done soonest.
https://www.sau.com.au/forums/topic/219209-servicing/#findComment-3867436
im pretty sure there isn't one thing i haven't done to a car in the way of services, manual conversions, engine conversions, turbo conversions, injectors, suspension, wiring looms (from the start), custom manifolds, exhausts, diffs, clutches, full rebuilds (now doing rotarys) trans and tuning!! but when it comes down to it unley nissan have information and equipment for these cars that no one else does, their technicians need to go learn about each car etc, so if i didn't do it all myself i would go to unley nissan for a service anyday. They are qualified and in the game, They get beaten down to their knees if a vehicle comes back with issues.
Edited by Ryanrb25
https://www.sau.com.au/forums/topic/219209-servicing/#findComment-3868382
Thats cool then - personally though I would feel better taking my car to a known reputable workshop that has been tried and proven... but seeing people talking highly of Unley Nissan I may consider them for future references.
https://www.sau.com.au/forums/topic/219209-servicing/#findComment-3868465
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
