I don't think I have seen a white R32 around how long have you had it? I go past the Soarer and Supra every morning as well I'm usally driving the Yellow Mazda with the really loud exhaust.
Good to hear you get your License back, I've heard that some brissy cops are up here teaching ours how to use the new DB meter, bit of a blitz going on.
  • Replies 167
I heard a little story a while ago that someone went to Rocky I think, to pick up there R32 GTR and on the way home it burst into flames. I'm not to sure what happened just heard the story, has anyone in Central Highlands heard this?
Hey Mega GTS-4... that thing sounds really cool...
are you happy with then end result or are you going to keep modifying the RB26...
I think it is a great way of getting a GTR... and because it is all it a GTS body everyone thinks it is just another skyline... little do they know...
The other good thing happening at the moment is the 88-89 R32 GTR's that are available from many importers cheap... particularly prestige motorsport or the likes... I was thinking that a cheap R32 that had a big list of mods would be really cool... even if it came over and the RB26 had some serious issues with blowby and the like... perfect time to build a RB30 bottom end... massive horsepower and a 4WD... I like the sound of that... maybe it is time to sell the old Q with Boost... although it has been a faithful rig and I would like to get it down to the 12's before reassigning it too light track duties... (I love the Clubsprint Meets at Ipswich)
anyway I hope you guys are all running at the 16th... and if not atleast come and say Hi...
check this out
www.garagespank.tk
check the members out... if you see this crew at the drags come and say Hi...
there is a grey 32 gtr in emerald..gary currie, sparky at kestrel,drives like a girl and won't race me.(hope he is reading)
he had a small electrical fault and melted a coil pack and ignitor collector.Alls good know except for his driving...he he..
Joe biddle owns th torana i think.
I'm Rick Hansen by the way, lived in emerald for about 5 years 94-99 and worked at national fire and security and chubb security with troy humphries (one of the other toranas). You'd have to know peter tease and wazza at bp hey.
Hi Rick, I've seen the Grey GTR a couple of times usually just putting around but I haven’t seen it for a while now.
The story I heard was supposably that the Sky that caught a light was only just bought.
No sorry I don't know peter tease and wazza, I get my fuel from Shell for both my cars, I think I'm a bit of a hermit.:)
Shawn.
that car that burst into flames was an R33. He was from Blackwater I believe. There is a pretty bombed R33 at blackwater too we had a look at it the other week it was in at Garths shop getting some work done on it. Appreantly it was one of the first R33 to be imported to australia (been here since 1995).
We also have 3 red 300zxTT's 2 seaters here. 2 0f i know have been to Willowbank 1 has run a best of 12.56 the other 13.8 & the 3rd one is owned by a old dude that wouldn't race it. At one stage there was 5 red ones here but one has gone to St George & the other went back to Brisbane.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
