Hey guys,
Got an RB26/30 and a big single turbo - the bonnet is so close to shutting but just wont shut!
What have you guys done to get around that?
Im trying to avoid spacers, was wondering if there's a carbon bonnet or whatever thats got great clearance?!?!
Cheers :P
https://www.sau.com.au/forums/topic/219307-bonnet-wont-close/
  • Replies 119
Posted Images
Well yeah guess i could, but would really rather not :D
Good suggestion though
Translation: Shit didn't think of that.............. :)
Were is it hitting? Timing belt cover or the turbo.
If you get a genuine c/f bonnet it doesn't have the support frame, as it is very strong/stiff on it's own. I have a full c/f bonnet made by Custom Carbon (currently not fitted to car and at the mechanic's w/shop), it consists or 3 layers of carbon and resin, that's it, no fibre-glass, etc.
spacers are the only way to go...
on the xmember or on the bonned hinges
Looks that way unfortunatly
I rearranged my piping and put 10mm spacers in the hinges.
Cheers :D
Long time no speak!
lol, it was suggested by the mechanic and yeah - not a fan of the idea
Hitting turbo, im going to get prices on carbon over the next few days and if i go down that path (currently spacers is the go) ill spray it white to match
i dont know if anyone has thought of this, but any one thought of using LD28 engine mounts instead of hacking holes in bonnet subframes?
this was suggested from a retired mechanic who helped with my hilux rb30 conversion.
Edited by nizmonut
DIfferent mounts cant fix the problem, as the sump is about 4mm from the crossmember
then theres def something wrong my rb30/26 has 28ml of clearance from sump to the nearest piece of crossmember/steering rack....... and still have room for the 50x50 ml overkill strut brace over the top of the motor.
Edited by nizmonut
Im guessing your isnt AWD, we have a diff/adapter plate to fit under the motor as well
Edited by Adriano
That must be a HIGH high mount manifold or is the turbo THAT big?
Cheers
Gary
Here's a pic :)
It was taken a while ago when it was dummy fitted together and before anything was done to the sump
Hey Steve!
Just occured to me now: WTF are you always bringing the auto supra to DECA. HTFU and enter the GTR, once it's up and running :)
PS: I want to see pics and details :thumbsup:
lol, the supra does so well down there though, 3L, small turbos - great response :)
Im organising a car trailer for the gtr so i can bring it to the deca masters ;)
Ill show you around it when i see you next, take it for a 'fully sick' lap of shepparton, basic details are;
3l bottom end
2.6 head with a little bit of work done
giant turbo
built bottom end
dry sump
triple plate clutch
talentless driver
ap racing brakes
tein suspension (got to get swaybars sorted asap)
there's more to it but thats the rough details :)
+1
Is it RWD?
lol, I did predict this happening months ago when you showed pics of your worlds highest high mount. I would look at possibly a more suitable turbo/manifold combo which will not only clear the bonnet but make the car nicer to drive, but I know you have your heart set on the mack truck version. in which case I say just go the spacers and be done with it. it's the easiest cheapest way out of this problem.
lol so true. Well its all a stop gap to be honest, got a spare rb26 at home that im going to get built and do the dry sump thing with aswel. It will have some -10's so clearance isnt an issue once i get that one back in
pffft bonnets are for sissies :down:
lol
Damn that's a huge turbo! :wub: How many Hp?
I wanted response with my rb25/30 combo, so i fitted the smallest recommended turbo GT3076R; also a fully built engine.
Love it! :ermm:
Can't wait till the next DECA, will be awesome.
How many hp? Oh, its got enough :whoops:
Ill see you at the next one :whoops:
Have you got it in the car yet?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
