  • Replies 62
You dont need semi slicks to crack 2 min barrier, especially if you dont have a speed limiter. Even with the limiter and normal rubber i can lap in the 1:56s.
Im glad i kept using road rubber until a time i was comfortable with how the car moved around at speed. The semi slicks have much higher levels of grip and let go much quicker and at higher speeds. Oh and much easier to flat spot or damage.
Street rubber means you have more fun, and learn more about your car.
hey Tim, the format was a bit funny yesterday with only one group, normally we can split up between them and offer tips etc while someone else is out. And yes, they did all turn up as soon as you left :)
Hope u fumigated that helmet pete.....
As for tyres, I think Roy is right, you can get under 2 min on street tyres, but it takes a pretty committed lap....the thing about the cheater tyres is they can be cheaper in the long run coz you don't kepp chewing up road tyres in 1 day on the track, at least they last 5-6 days....
Had a great time with those that made it. Lots of runs as not a lot of cars. Wish there some faster Skylines though, He he. Maybe next time. Paul 0Z97 GTRv might get his suspension sorted by the next one as it was like following a lawn mower as he was checking out the grass a lot on sides of the track.
lucky that 120y wasn't there John :D
Ive had my CAS replaced, it appears that was causing the missfire problem so there will be at least 1 faster skyline there next time......
Yes that thing's a little narrow missile, fun to drive behind and watch it twitch around the place. Hopefully more cars and less bikes next time. Need some faster Skylines, maybe Andrew Ho?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
