hey guys just a quick question about installing a pod, i've never done it before because my first car already had on when i got it.
so atm my car is in the driveway and so far it looks like this
now i know i have to attach it onto the worm clamp, but whats the thing with the wire coming out of it? and what do i do with it, do i take it out and unplug it and screw the filter straight in?
Thanks :]
Edited by morbsy
https://www.sau.com.au/forums/topic/219589-installing-pod/
hey mate if u werent too sure about it you should have asked when i sold it too you,i wud have been more then happy to explain it further and help you out.
and another tip,if you can enter the shop from the rear drive way as you wont scrap there like you did at the front one...i lernt that the hard way too ahaha.
Jack
https://www.sau.com.au/forums/topic/219589-installing-pod/#findComment-3875982
im sure he will be fine.
from the cruise wasteland thread:
i have a few times, twice in one night once, and the first thing they say is pop ya bonnet, and just start looking for defects, i got done for a loose pod filter once.
not worth the risk.
Edited by ted180
https://www.sau.com.au/forums/topic/219589-installing-pod/#findComment-3876029
hmmm i have a stock air filter and was wondering about that plug when you pull it out while the car is running it stops the engine, anway getting rid of it should i get it removed as i want a different air flow system not the gay standard one.
cheers... michael
https://www.sau.com.au/forums/topic/219589-installing-pod/#findComment-3878421
cheers... michael
'that plug' thing is your AFM (air flow meter) and all external ones like most grey imports are tempermental crap.
if your going to upgrade, a cheap replacment would be a Z32 but your going to need a remap to run it.
installing a pod is one of the easier things to do. take the AFM off the indunction pipe and attach it to the pod while its outside the car, its alot easier that way. then put it all back together. make sure your dont feck the plug by forcing it off the AFM, just wiggle it side to side and should pop off. its like a 10 minute thing to do.
Edited by Import S13
https://www.sau.com.au/forums/topic/219589-installing-pod/#findComment-3878533
i wouldnt say a z32 afm is a cheap replacement..
https://www.sau.com.au/forums/topic/219589-installing-pod/#findComment-3878749
haha just remember the plug and the "black pipe thing" known as the AFM [air flow meter] is a must you cant get rid of one but changing is ok i guess but it wont do anything good for your car unless you do the whole intake to eat more air
then you need more fuel
when you pull the plug out the car dosnt know hoe much air is being taken in thats why it dies because the ECU dosnt get the messages
other than that the pod filter question once you do it the first time you will be able to change them in 10min after that
you will get it :D
wing nuts are the best to screw it to your AFM thats all you really need to do (and put the gasket inbetween)
https://www.sau.com.au/forums/topic/219589-installing-pod/#findComment-3878893
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
