hey guys, i am willing to help out in anyways needed (except dressing up as a girl, i said no bam bam!) heheheh anyways i am gonna send a message to GTNIK today to ask him whether he is still interested in joning us for the show :P i'll let ya's know the details tonight hopefully :)
adrian :D
  • Replies 504
Killer, We'll be more than happy to have you with us:D
Troy, I thought that the blue for the guys shirts and maybe red for the girls:D
Adrian, Do you want to enter your car? (Please)
Any offers of girls are kindly accepted, I'll put them through a rigorous selection process;)
I have spoken to Lloyd this morning and should have a map of the hall tonight which will show where we will be and the shape etc.. Was I looking into tv's???? I 'might' be able to 'borrow' a projector from work for the weekend, not sure what to do about TV's unless someone here works for a rental place....
Adam, we had a thread about the meeting, will make sure we give heaps of notice for the next one. Definately want your car inside. Ken may be entering in another display so we can't count his car just yet.
Anyone speak to Dan (Sly33) yet to see if he wants to go in with us??
Brett
Edit: Ohh and I have PS2 and GT3.. Also have Midnight Club II which I think you can link race as well.
I chose Red ..... i didnt like the MAS yellow .... yellow doesnt really look good on a chick unless shes really dark skinned .... which most of us chickies arent :P so red is fairly universal .... suits many people and stands out.
Originally posted by GTS-t VSPEC
We are also planning on having a flyer with details of SAUWA and the forum. If there is anyone who can have these printed really cheap that would be great, we're only doing them in black & white.
What he means to ask is ..... Does anyones work have a good quality photocopier :P
and brett yes u said u had a contact with a rental company thats what i figured for the TV's.
think its $10 a day per tv from radio rentals so if we have rent them thats not to much.
we need to nail down with ken if hes with us or not. and work on dan(sly33) to go with us instead of rollaboyz seeing how much hes has to spend on the car now.
October 18th ??
Well that's easy , I won't be at any display cos is the penultimate round of the Speed Event Series and can't afford to give the points away.
Sorry but didn't realise that was the date.
Possibly could come there Sunday but car will be pretty grubby.
Cheers
Ken
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
