BTW, I've ordered one of the Gasweld ones @ $215 ( post-2420-1213223546_thumb.jpg ) so I'll give some feedback when I get it and try it out.
Won't be able to give feedback for a while since Gasweld are out of these jacks. Won't have any in stock until late August :(
  • 3 months later...
  • Replies 158
Posted Images
  • 4 months later...
I went and checked out that jack on sat, the saddle height is fine BUT the rear of the jack(143mm) is where u will have trouble esp if u want to reach under the front cross member.
I need i trolley jack that is under 125mm at its highest point.
I suggest we keep looking :domokun:
Regards
Trev
Hmmm, I was looking at this Omega jack was well on http://www.tradetools.com.au/Catalogue/Pro...tCode=GJLUQ1500 GJLUQ1500 jack, 63mm at lowest point but it's not super long.
Its cheaper than anything else I've found so far ($275 + postage to Vic) and the car is approx 13cm off the ground on the side skirts, do you think this could get to the cross member?
Or, is there anything better under $400?
UPDATE: Also found the "J041", from https://www.machineryhouse.com.au/Products?stockCode=J041# , its $229 incl GST, only 90mm off the ground but looks like its long 84cm and 51kg, they make a racing version https://www.machineryhouse.com.au/Products?stockCode=J042 but its shorter...
Note: I do know this thread is ancient but it still seems relevant.
Good Jack: https://www.machineryhouse.com.au/Products?stockCode=J041 It's actually a tradequip jack. Double pump too
not "super low" profile or light so best for the workshop (it's bigger than it looks)
The SPI never made it to production if anyone bothered to contact the Oz Dist.
I would also be dubious about supercheap Ally jacks as they've had so many recalls.................
Also a true ally "racing" jack will only be rated to about 900kg.
I found if the car was just a smidge too low for the jack, i'd just drive onto a peice of wood or wide paving brick under each wheel and that would gain enough height to get the jack under.
Edited by mosoto
<cut>
<cut>
True, thanks for the info. Yes avoiding the supercheap auto jacks for now, I'm trying to buy quality.
Its for personal use, not a workshop, I only visit the track every 6months if I have the $$$ so I'm not too worried about weight (at the moment).
The second jack I mentioned can only support 1000kg, its 19.5kg and a little shorter than the first jack, its 74cm vs the 85cm.
As long as I can jack the car up and the jack will last a long time I'm happy :P
Also the price is very reasonable for both of them...
For those of you who are looking for the ultimate jack, I am now able to supply AC Jacks.
Prices:
DK 13HLQ $950 + Shipping
DK20 $620 + Shipping
These are the lowest Jacks I have seen available that meet Australian Requirements and their quality is second to none.
These come with a full backup servicing, a stocked full range of spare parts and turn around for any servicing is usually within the week.
• World-class garage jacks.
• Designed for heavy-duty, intensive and commercial use.
• All models – except for DK20 - are delivered with quicklift pedal.
• Simple and safe to operate.
• Dead-man’s control on lifting and lowering.
• Built-in safety valve to ensure against overloading.
• Increased manoeuvrability.
• Low weight.
• Ergonomically designed handle.
I don't agree at all, just look at the profile. It raises very quickly. Unless they have another?
thats not the low profile one i just bought a new one two weeks ago
68mm at the front and its a long reach jack too
Anthony which product name did you buy? I've looked online and the "low" jack for Bluepoint is the cheap one posted above, but its priced at $500 or something crazy.
Did you pay more $$$ for a super low version or something?
part number is SNX1LLTJ
cost me $550
Interesting, had a quick look on the website and found it as ~$540 as you mentioned and supporting 1 tonne but that was it, no more info.
This old post, which does appear to the be the pictures of snap-on jacks we had earlier claim its most likely a re-branded Torin jack:
http://www.fatwallet.com/forums/hot-deals/688353
Probably this one:
http://www.torinjacks.com/ProductDetail.aspx?ProductId=10
In the end I bought:
http://cgi.ebay.com.au/1-5-TON-ALUMINIUM-R...%3A1|240%3A1318
Which appears to be the Torin 2 tonne low profile jack:
http://www.torinjacks.com/ProductDetail.aspx?ProductID=17
Its not super low or super long, but its good enough, and its $330 with dual pump / dual piston design so I'm happy.
If you do search on ebay use the part number, and ensure you tick the "search description" button, the seller seems to list one every couple of weeks....
Probably not the ultimate jack but its reasonably priced and is ~82mm off the ground with some length (>70cm's :banana:). And its 23kg so fairly lightweight.
Thanks,
Gareth
found the blue point jacks - 68mm at the front and real long.
$509 incl GST
if anyones interested in NSW - rep is real local to me, let me know
blue point is lower
cost me $550
i'll have to check my paperwork and call the rep again, i hope they havent gone up again :)
i am in the market for a new jack also.. ive dealt with these guys before and most of their stuff is pretty good so im assuming this would be aswell.
$330 isnt too bad.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
