So My Jack Just Shat Itself..
Sarumatix
Shop is in Smithfield. It is good, however the pin that holds the top handle in place fell to pieces and I haven't had time to replace it.
The foot pump seems to be good, however I really need to go over it and make sure everything is tight.
I'm going to use this jack at the track (even though it weighs 50kg) because the reach and height allows me to easily change tyres without having to drive onto blocks to get jack access.
hmm.. maybe this jacks a little to hardcore for what i need.
I just need a safe reliable jack, with added support of jack stands that will alow me to work on my car.
What would you recommend?
  • Replies 158
Posted Images
I'm a massive fan of Kincrome Tools and they have just released a Workshop range so I would check them out, although it really depends on what your budget is and what you want to use it for. Alloy is great as it is light however not always the best for heavier cars.
Your main concern should be the reach and the clearance.
quick shot of my blue point with some reference lol
still to make it to the engine cross member from the front of a kitted 32 i needed to use a 2 inch thick bit of wood
looking for a jack as well was looking at spending at around 200-250
what do people recommend?
was goin to look at the autobarn aluminium racing one but it doesnt have long reach?
would this be good enough for just changing rims at the track and oil changes?
  • 1 month later...
so whats better the blue point or CP?
price isn't really a problem, more concerned with the specs/reliability
to what i can gather from the pics is that the cp is a tad higher but the blue point is a tad shorter?
Edited by dori31
its hard to say..
i think bluepoint is lower (see below) but the cp definitely looks longer :s
cant find specs for the blue point tho would be good to get some
anyone know any vic retailers of the cp?
Edited by dori31
  • 3 weeks later...
I'm also in the market for a jack.
Went through the whole thread..
saw this one a few times https://www.machineryhouse.com.au/Products?...Code=J041#specs
did any1 here who mentioned it, end up getting these? any comments on it?
Also going to look at the GASWELD one..
I only need it for home use so weight won't really matter, needs to be decent low profile.. nothing over 10cm.
and not looking to spend too much above $300 - $350, since i won't be using it often.
However as every1 else, would much rather pay more for quality, than go cheapo n replace within a few uses.
  • 1 month later...
I've got the Bluepoint super low floor jack like the one pictured above...
Definitely a great jack, abeit fkn heavy!
Only dissapointing feature is the reach not being longer... I need one of these to reach my cross member on the 180sx :D
Although having said that... Still can't do much about it as my car is pretty low. I don't think any other jack would do a better job than the Bluepoint one. Reaches the diff no dramas...
My Bluepoint jack + Astro Products ramps = Win ;) No ghetto spec wooden blocks for me lol
PSI Part (Shane): Can you still get those rubber pads for the jacking points still pictured in one of the previous pages? The Bluepoint jack doesn't come with one so I went to Clark Rubber to made one. It's effective, but would much rather the proper stuff as per the one you posted previously...
Cheers,
Andy
    • Trail braking done right, should have the rear unsettled, such that you're actually turning the car by a noticeable amount WITH the brakes, and hence noticeably less steering input.
    • No you don't. Just no more driving in the wet, and clean your window manually before you drive
    • I'm not sure if they tick your boxes, but Haltech would be my pick. I'm an Adaptronic guy from way back, and Haltech acquired Adaptronic to basically get Andy, AND his IP on how he does things like fuel modelling etc.
    • Just on this, as there's a huge issue in your assumption Dose.   The logic you've given, is the same logic old school NA guys give for "needing back pressure" in an exhaust. If you free up an exhaust system, and keep injecting the same fuel in etc, at the same timing, you'll typically drop power. Freeing the exhaust will often make an engine want a little bit more timing, and even sometimes a little more fuel, but then it'll make even more power.   There's many mods people do and "get no extra power" when running a comparison on the same tune. Imagine a car tuned for 91, but now we say put 98 in it, see no difference. But as we now have 98 fuel, you can run more timing, and make more power, as the 91 was knock limited.   So just be very wary in your claim of "don't retune it and do a back to back and you'll see". The correct approach would be tune the car with stock manifold, swap the manifold to aftermarket, and retune it again. But no one wants to do that, and all the results we get are "this was stock, and this is manifold changed and tuned" and people put it all down as just the tune doing it.
    • Unplug ECU. Unplug TPS. Unplug boost pressure sensor. Now, all the wires, placing your ground (black) multimeter lead at the ECU end, measure resistance of the 5V line at the boost sensor plug. Then do the same to the TPS plug. Then do the same for all the other wires that relate to the TPS, or boost sensor.   All of your measurements should be very very low. You're looking to see if wiring is out of wack here.   Secondly, from memory on the R33 (not a neo motor, so I'm assuming an r34) the ground wire for the TPS and boost sensor are NOT equal to ground of the car/battery. IE, DO NOT connect ground of the sensor to the engine/body of car. You'll get a ground loop, and/or potentially screw shit up. In electronics, ground for a circuit, is not necessarily equal to ground of another circuit.   So this leads me to ask, when measuring your 5V, how are you getting 1.5V? Where are your multimeter leads touching for both the red and black lead on the multimeter?   If you're measuring power on the sensor wire, and putting ground on the car chassis or negative battery terminal, that could be all of your issues in "getting 1.5v". Electronics engineers can do some funky stuff with circuits, and when both sensors are on, it's enough laid to alter how the ECU is functioning.
