i have been doing a little bit of looking around for bolt on mods for a NEO RB25DET and came across the plazmaman inlet plenum which u can by with a throttle body and intercooler as a whole kit for about $3000 (thats the competition spec cooler and billet T/B) cheaper coolers available and an R33 T/B would fit. i was just hoping if anybody could tell me if they thought that this plenum ( you use the stock runners etc) would rival the GREDDY manifold. they also make a great looking Stagea specific cooler.
http://plazmaman.com/shop/index.php?action...&itemId=193
im a bit pissed of that i will have to sacrifice my traction control to do this but thems the breaks.
https://www.sau.com.au/forums/topic/220133-inlet-manifolds/
why on earth would i say that if i did this mod i would loose my traction control if i didnt have it in the first place. well know tha we have sorted out that little fact could someone please give some sort of feedback regarding the actual post which was about inlet manifolds.
cheers
https://www.sau.com.au/forums/topic/220133-inlet-manifolds/#findComment-3884264
where would i find the traction controll unit, fuse or what not if mine has it? (s2 rs4 s 98)
when i dump the clutch off the line it just wont spin em up but i thought it may just be my weak clutch or too much traction.
https://www.sau.com.au/forums/topic/220133-inlet-manifolds/#findComment-3884305
I suppose my question would be- can the $3000 odd be better spent on other mods for the car?
sorry but I am completely unfamiliar with what mods you have already
if that new plenum and TB is going to give you the power you need ( as you have all the other supporting mods already - ie after market ecu or bigger injectors etc ) then yeah go for it
but if there are other things you can spend $$ on then I would go with that
ie - just dont get it if its for looks/bling
https://www.sau.com.au/forums/topic/220133-inlet-manifolds/#findComment-3884334
my main reason for this is that i hate the throttle body and intercooler piping assembly going over the top of the motor when it can be moved quite easily. i realise a just jap bolt in cooler is only $500 bucks that uses the original return pipe but i just dont like it and that's it. i have a pretty stock car at the moment but it's not going to stay the way for much longer so i thought kill a few birds with stone or 3000 of them any way. cooler t/b and a good flowing manifold that will all bolt in without major modification and give great overall response and hp gain with head room for more modifications down the track. they guys at plazmaman advised me that the Greddy manifold is really only good for drag racing (WOT) due to its short runner design. well if i go through with it i will let u guys know about the results before and after any other modifcations.
RS4's dont have traction control due to them being AWD. mine is only RWD like a GTST R34 therfore it has traction control.
https://www.sau.com.au/forums/topic/220133-inlet-manifolds/#findComment-3884408
thats what i thought, still slides nicely though. cheers
https://www.sau.com.au/forums/topic/220133-inlet-manifolds/#findComment-3884448
Please tell me when you find one, I have used lots of brands and styles since 1999 and haven't found one yet that does all of that. I am currently using a cheap China GReddy copy on the basis that If I have to make mods to get it to work properly I might as wll start off with a cheap one. But that still requires washer bottle relocation, cutting a 75 mm hole in the inner guard and making a throttle cable adaptor the same as the original GReddy. So it's hardly "bolt on".
If you have no intention of upgrading the internals, then the best manifold is the standard one. Everything else that I have tried loses power and response and has issues with distribution.
Cheers
Gary
https://www.sau.com.au/forums/topic/220133-inlet-manifolds/#findComment-3886034
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
