yeh, everyone hears up and down reports on every single workshop, its just natural, but they have done everything right by me, even went and picked up the car for me (2hrs away).
ill run it in then go back and get the next lot of goodies, probably buy tess's old car also, and get the body work ready for the motor to be thrown into.
  • Replies 62
We can't wait to get it off its run-in-tune CJ!! And, the E85 tune :P
Extremely responsive set-up with the 30 bottom end & 35R, we're very happy with how it turned out!
Tess's 32 is still here, it's a complete rolling shell :down:
yeh kudos to trent and the guys :P
deffinatly looking to add some extra goodies once im able to get it back up your way.
ill have to book it in to get all the work done before the 16th?? or at least some of the work...
Run in tune dyno sheet.
going to hookup the boost controller and tune it properly tomorrow. also now running federal 595 RSR's all around.
hope to bring on boost earlier and rev it some more! o and hopfully another 100hp lol.
not sure whats wrong with the clutch, the car didnt even make it onto the dyno, it hasnt even seen 500km's i dont think. nor has it seen any abusive driving.
the gold coast has been in wet weather for the last 2 weeks so iv hardly been able to put any load on the car anyway, so the tyres are acually more slippery then the old nagnkangs i had on there....
dont know whats gone on.... but feeling pretty annoyed... will post photos of the clutch when we get it out.
  • 6 months later...
ok so a few months later... New twin plate in the car, little harder to drive then the Jim Berry but feels good at the moment.
car is sitting on about 490atwhp, just finished driving it from the gold coast to melbourne and back again, EVERY tank of fuel i filled up at 420-440km and the fuel light wasnt on yet... so fairly decent fuel economy for the power it has...
Did a bit of a highway squirt and lost oil pressure at about 7,000rpm in 5th gear... light came on just as i grabed the key to shut it off, just as i went to turn the key pressure came right back up to normal, scared the hell out of me, so now getting rid of the N1 oil pump and putting a ASR 8.5L sump in there with a Nitto oil pump (purely for peice of mind).
also doing a E85 tune and hoping to get close to that 600hp goal i originally wanted, will be a stretch out of the baby 3540 turbo with .86rear...
CJ
ps... anyone on the goldcoast brisbane area own a supersnake mustang 2009+ or a 2010+ srt8??
forgot to mention the fuel side of things...
Twin feed rail
880cc injectors
040 Lift pump
2.5L Surge Tank
2x 044 pumps mounted to the surge tank.
what is that piece in the boot and why do u need it if u don't mind me asking?
Dont ask about the clutch. end of story.
bit of a squirt yes... umm...on track of course.
reason for the road trip...i always wanted to drive my car along the great ocean road... just once, was a great experience but now that it is done i wont be driving that car down there again.
DVS32R - Also tried Filling the Sump up an extra 1L of oil...didnt work.
Riley - because iv gone for a new turbo and E85tune, which was always the plan, so i just had it all ready for when these come along.
ya im just trying to learn/get ideas so i dont even know what that piece in the boot is, i thought it was an external fuel pump. not sure
Yeh its 2x 044 fuel pumps with a 2.5L surge tank.
car just pushed out 630rwhp using the new GTX turbo on e85, still the 35series with a .86rear on it, 27psi.
think thats the max the little .86 rear can do, as we tried 2-3psi more and didnt gain anymore power.
still...630rwhp is a great effort for the baby turbo! big thanks to the guys at mercury! :)
CJ
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
