Gday everyone, this is my 1st post.
im seriously thinking of getting a R33 GTR.
What would be needed to get the car into the 11-10's 1/4mile ?
I have a very lame knowedge of skylines and have been a holden fan. Currently owning a VXSS tricked up and it runs a 12.2 on streets. but being 22 i need more. i want to see 11 to 10's and its getting time to sell the VXSS.
How much money would need to be spend on the GTR to see 11's ?
and whats a good imported R33 GT-R worth ? im guessing around 45?
any help would be AWSOME !!
thanks
MELV
https://www.sau.com.au/forums/topic/22066-help-getting-a-gtr-r33-into-10s/
  • Replies 56
A guy on this forum has a R33 gtr running ~10.4sec 1/4 miles
Name is Leewah, give him a PM and ask about the cost. My guess is about another $25-30k after purchasing the car. This would be a quality job that is still drivable
the r33 gtst that they use is up for sale for $40 000 something i think which seems like a lot cheaper way to do it to me, they also said that the car is capable of alot more but there not touching it cause its for sale its 400hp at the wheels its suppost to be the fast 2.5 in the country at the time
if you dont get much out of them try tony rigolies work shop i dont know where they are but the deal with some serious cars and they have a shop in sydney and on the goldy they have an r33 gtst that there trying to get 600hp at the wheels out of with similar upgrades good luck
400hp at the wheels is what I've got now with the NOS kit.
MELV
Well with a GTR you first have to decide what target you want. Do you want 11's, or do you want 10's
There is a HUGE difference and cost between the two.
Also a GTS-T is NOT a GTR, so dont compare the two....anybody.
its like saying "my mate bought a torana and did it up for a full cost of $50,000 and it ran 9's", and you spend 50k on a GTR and you get a clean stockish GTR.
If you want a clean GTR, a friend is selling his 33. Pm Leewah, or SIRVROOM.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
