okay soo R33 has been defected and i need the following parts,
-stock smic inc. piping
-stock rims with good tread
-stock front bar (silver if possible)
-stock exhaust dump to muffler tip
all lending of parts will be compensated accordingly, if parts cannot be borrowed i can/will buy them.
car has been sitting aroung for 7 months thought i should get off of my arse and get it done
please contact me via txt on 0430 402 862 as i work weird and wonderful hours.
cheers
jason
cheers
jason
have got
have added you on msn to discuss :)
If you want to borrow mine James you could, except mitch still has them bastard :wub:
I'm pretty sure all C-spanners do all coilovers man. Mine are for Tiens and have used them on cusco's and whatever Mitch is running.
As soon As I get them back from him you can borrow them :)
pair of tein c spanners for sale $50
urgent! Hey, i was wondering if anyone has stock factory bov piping for a rb26dett, r34gtr engine preferred. need the recirculation piping to make the system full plumb back. Want to borrow or buy if i have to. PLEASE PM me.
Has anyone got a set of 6 working neo coilpacks that i can borrow as
i want to see if one of the splitfires has died and causing me major issues.
I am a little pi***d as i have only done about 3000 kms on them.
I am just trying to rule things out at this stage to get the car running properly!!
have got
have added you on msn to discuss :D
cheers mate i have been rather busy of late will jumpon by the weekend hopefully to discuss
cheers
jason
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
