okay soo R33 has been defected and i need the following parts,
-stock smic inc. piping
-stock rims with good tread
-stock front bar (silver if possible)
-stock exhaust dump to muffler tip
all lending of parts will be compensated accordingly, if parts cannot be borrowed i can/will buy them.
car has been sitting aroung for 7 months thought i should get off of my arse and get it done
please contact me via txt on 0430 402 862 as i work weird and wonderful hours.
cheers
jason
cheers
jason
have got
have added you on msn to discuss :)
If you want to borrow mine James you could, except mitch still has them bastard :wub:
I'm pretty sure all C-spanners do all coilovers man. Mine are for Tiens and have used them on cusco's and whatever Mitch is running.
As soon As I get them back from him you can borrow them :)
pair of tein c spanners for sale $50
urgent! Hey, i was wondering if anyone has stock factory bov piping for a rb26dett, r34gtr engine preferred. need the recirculation piping to make the system full plumb back. Want to borrow or buy if i have to. PLEASE PM me.
Has anyone got a set of 6 working neo coilpacks that i can borrow as
i want to see if one of the splitfires has died and causing me major issues.
I am a little pi***d as i have only done about 3000 kms on them.
I am just trying to rule things out at this stage to get the car running properly!!
have got
have added you on msn to discuss :D
cheers mate i have been rather busy of late will jumpon by the weekend hopefully to discuss
cheers
jason
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
